What is this roof tinted plastic moulding for?
Discussion in 'Gen 4 Prius Main Forum' started by Bristolbob, Mar 18, 2023.
  1. Bristolbob
    Bristolbob New Member
    UK
    What is this tinted roof moulding called and does it serve any purpose? Am trying to locate the source of a bad rain leak so was wondering if it's ok to reseal around this piece. Thanks in advance.
  2. ChapmanF
    13,198
    I suspect it's just covering where the sheet metal does something unsightly to support the hatch hinges. If the molding comes easily off, you should be able to see all the concealed mysteries (which will often include a lot of rotting leaves).
    Bristolbob likes this.
  3. Elektroingenieur
    2,506
    3,227
    Three Touring
  4. Bristolbob
    UK
    Thanks for the suggestion. Once I figure out how to remove it I will do just that
    That is fantastic! Could not have wished for a better reference. Will figure out how to follow the instructions in reverse in order to remove and check under the moulding.
    #4 Bristolbob, Mar 18, 2023
  5. Elektroingenieur
    2,506
    3,227
    Three Touring
    The Repair Manual (more info) has illustrated procedures for removal and installation, under Vehicle Exterior: Exterior Panels/Trim: Roof Garnish; there are some steps that aren’t obvious, such as applying protective tape to the side finish moulding sub-assemblies. To get access to the nuts, you’ll also need the procedures (each with about 70 steps) to remove and reinstall the roof headlining and related interior trim.
  6. Bristolbob
    UK
    Thanks again for the additional information. Sounds like it might take a while but it has to be done.
    Elektroingenieur likes this.
Loading...
