What is this tube?
Discussion in 'Gen 3 Prius Main Forum' started by Mike72903, Oct 23, 2023.
  1. Mike72903
    Mike72903 Junior Member
    57
    Fort Smith, Ar
    2010 model. Putting in a used brake master cylinder. The tube in question is the vertical black tube with a gray inside that’s just beside the assembly I’m putting in. I assume it’s not supposed to be open like it is pictured. What goes on it? should it just be capped? I don’t recall taking anything off but I am be mistaken. I was surprised to see it when I installed the replacement unit. IMG_0083.jpeg IMG_0083.jpeg IMG_0083.jpeg
  2. Tombukt2
    Tombukt2 Senior Member
    9,596
    1,681
    Durham NC
    That is the feed black hose from the lower portion of the brake reservoir goes to there not the upper hose but the very bottom on the bottom of the brake reservoir that black hose will go to that gray fitting and there's a slide clamp that comes down and secures it.
    Johnny Cakes likes this.
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,022
    766
    Virginia, USA
    Ya gotta love this forum. Post a random question -- get the definitive answer within the hour.
    Grit likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,329
    6,005
    Columbia, SC
    It's the "this car may never work right again" tube.
    I've had a few of those over the years.....
    Grit and Tombukt2 like this.
  5. Mike72903
    57
    Fort Smith, Ar
    Excuse my confusion please. Are you talking about the circled tube? IMG_1208.jpeg I should have highlighted it in the original question instead of trying to describe it.
  6. Tombukt2
    9,596
    1,681
    Durham NC
    Hold on I'll be back at this silly car in about an hour and I'll tell you because I'm standing here staring at it with the wiper tray out getting ready to deal with transmission silliness or flex plate or somewhere right there at that connection.
  7. Tombukt2
    9,596
    1,681
    Durham NC
    There again that black tube has a black rubber hose that goes up about 2 in '90s over towards the valve cover and connects to a gold metal tube that's bolted just to the side of the EGR valve and goes down to the intake with another rubber hose connected to it just beside the air box.
  8. Montgomery
    Montgomery Senior Member
    2,254
    2,240
    Orange County, CA
    What would be helpful is if the person who answers the question shows a photo of it connected to whatever it is supposed to be connected to.
    Tombukt2 likes this.
  9. Mike72903
    57
    Fort Smith, Ar
    Found it, thanks for taking the time to help. Not sure why I would have taken that hose off to remove the brake actuator but all’s well. Here’s hoping the used replacement actuator actually works.
  10. Tombukt2
    9,596
    1,681
    Durham NC
    Have to resize and do a bunch of dances to do pictures so just look at the gold tube right next to your EGR valve follow it till it connects to rubber over by the brake actuator and that piece of hose plugs into that black tube that's empty I'm pretty simple stuff.
  11. Mike72903
    57
    Fort Smith, Ar
    Your description was fine. Thanks again
