What is this?
Discussion in 'Prius c Technical Discussion' started by Javierz0509, Jun 16, 2017.
  1. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    I recently notice this is on the L level, is this radiator fluid?
  2. JC91006
    16,482
    8,400
    Just ask the dealer to top up next time you go. Not worth buying a gallon. You need half a cup
  3. Prime Example
    Prime Example Junior Member
    58
    99
    Shenandoah Valley
    I agree...looks like the antifreeze. It's that, or the last time your mechanic was changing the oil, he spilled the Starbucks Pink Drink into the container. Either way, it's low.
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    No - the engine coolant filler is near the driver's side of the radiator at the very front of the engine compartment.
    The reservoir in your photos is described in the owner's manual as the "Power control unit coolant reservoir". But both this and the engine use the same actual fluid, again according to the manual.
    Javierz0509 likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    It's inverter coolant. Same stuff as engine coolant but different system using a different part of the radiator. I have some in my garage. Too bad you're half way across this giant state. Hopefully, JC is right and a dealer will top it off. ;)
    The bigger question, in my mind, is why is it low?
