What is this?
Discussion in 'Gen 2 Prius Technical Discussion' started by Dacus_Malus, Jul 4, 2019.
  1. Dacus_Malus
    Dacus_Malus Junior Member
    26
    Hello,
    When I bought my Prius, i found somethin in the trunk, near spare wheel.
    What is this?
    Thanks!
      File size:
      189.4 KB
      File size:
      147.9 KB
      File size:
      158.3 KB
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Oh boy is that a factory G3 External Hybrid battery charger only available at the dealer?
    You may have hit gold there dude. The fact that its all in Japanese is a good sign. Only available at the dealer. Very expensive. And never offered for sale to the public.
    But the fact that that it was in the trunk probably means the hybrid battery in the car was having issues and they used that charger to fluff it up for resale.
    Tell us about the car what year how many miles on the car and what kind of mileage are you getting and btw congratulations.
    This thread will soon become very busy lol.....
    Do this...start another thread in the G3 section and label the thread: IS THIS A DEALER HYBRID BATTERY CHARGER?
    That thread will go crazy lol.
    #2 edthefox5, Jul 4, 2019
    Aaron Vitolins and Moses Bruh like this.
  3. Dacus_Malus
    26
    ok, I will open a thread in G3 section.
    My car is a 2006 red Prius executive.
    I bought it in 2017 with 220 000 km and now it has 280 000 km.
    I have no problems until recent (last month) when the HV battery star having problems.
    Now (after I change a block of cells) the car runs very good....but who knows?
  4. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Ok I thought since you posted in your signature you own a 2000 prius I assumed you found it in that car. So whats the 2000 Prius you have listed in your signature? In the future please be more clear what car it is and where you live. You are asking for help.
    I have never actually seen the the Japanese Dealer charger for the G2 so that's what you have so don't bother posting on the G3 thread you have a factory G2 hybrid battery charger. A legendary charger. That would make more sense a G2 is having battery issues.You could have used this charger to fully charge and balance the entire battery pack when you worked on it.
    Back in the day a G2 engine would die and people would try to limp home on the hybrid battery only and drain the battery so deep the car would not start. Had to get this charger imported from japan to the dealer to fix that. $$$$$. Los of posts on that years ago.
    There is a new aftermarket hybrid charger lots of us use called Prolong. Found at hybridautomotive.com. Works very well can extend the life of a bad battery. Mine started going bad almost 2 years ago and using the prolong it has gotten me another 2 years.
    Data Daedalus and Raytheeagle like this.
  5. Dacus_Malus
    26
    How I conect this charger to my battery?
    I have to remove the battery from the car?
    The charger input is 220-230 V?
    Where I can find a tutorial how to use this "legendary charge" ?
    Thanks!
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    There is nothing on that charger that would plug into any normal connectors on a Gen 2 HV battery. Assuming this is a HV battery charger, at a minimum, there would be an adapter harness required. I also noticed it has something marked as (12v)? And nothing showing it as Toyota. No part number, no nothing...
    Look through the link below. I believe this is one of the Toyota HV charger. Perhaps a newer model, but it looks a lot more involved than what's pictured in this thread. Also looks like Toyota charges the HV battery via the inverter connections.
    https://static.nhtsa.gov/odi/tsbs/2015/MC-10152247-9999.pdf
    #6 TMR-JWAP, Jul 5, 2019
  7. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Never seen one never even seen a picture of one much less any info or schematics. Its proprietary.
    I doubt its 220 volt ac input its usually 120 volts in. Japan uses 100 volts but not a big deal with electronics usually. Not alot of current produced as the charging current is highly regulated. On the Prolong for instance its capped at 330 milliamps.
    So one plug is ac in and the other plug is 200+ volts dc out to the battery. If i could get my hands on it and open it up it would be very easy to see whats what.
    But be aware your missing the charging cable which bolts to the hybrid battery. You would have to install one to make it work. Prolong for instance comes with a cable you install in the battery. There is no charging port in the battery you have to hook it to the battery side of the relays.
    Did they leave the charging cable installed on the battery too lol?
  8. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Part number is in japanese I bet. need someone who can read japanese. The lettering sure looks like Toyota to me. But i don't know as I have never seen the jap charger.
    Give us the dimensions of this thing. Looks pretty big to me.
    This thread is going to get busy. We love mysterys here. Especially the 12 volt lol....
    Data Daedalus likes this.
  9. TMR-JWAP
    6,404
    6,088
    Columbia, SC
    Sounds like we need a translator..
  10. TMR-JWAP
    6,404
    6,088
    Columbia, SC
    I would be EXTREMELY hesitant to go connecting this to anything without finding out exactly what it is and what it's current operating condition is. High Voltage is no joke and that device could evaporate in half a second if things go bad. I wouldn't want to be within 20 feet of that thing when it's going live.
  11. Dxta
    Dxta Senior Member
    1,937
    769
    Lagos
  12. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    Nope, sorry can't help here but yes PC does have some who can read Japanese.
    Data Daedalus and Dxta like this.
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    So you found this thing in your trunk 2 years ago and 60,000 km ago?
    Just now asking what it is?
    Bit of a delayed query.
    Skibob and Data Daedalus like this.
  14. Dacus_Malus
    26
    Only now I have battery problems.....so Just now I remember of this charger lost in my garage....
    Maybe tommorow I will make more pictures and I will measured it.
  15. spdracrm3
    spdracrm3 Member
    53
    46
    estacada or
    11: 14 U ○ l 66% 3/3 MH BATTERY CHARGER How to operate Ni-MH battery charger (1) Turn off the engine switch and connect the booster cable to the accessory battery (12 V). Press the START switch for 2 seconds. Start charging. (About 10 minutes) (3) If the CHARGE lamp blinks, charging is complete. (2) If a FAULT] lamp lights up, please contact your dealer. ACaution Do not burn yourself as the charger gets hot during charging. Please see the instruction manual for details.
    Google translate of text on side of charger
    SM-G960U ?
  16. Dacus_Malus
    26
    Thanks spdracrm3.
    The dimonsions are: 20 cm x 10 cm x 7cm, and weight around 1,5 kg.
    On the charger is this code:
  17. Dacus_Malus
    26
    And I "open" it:
  18. bisco
    51,476
    definitely electronic
  19. Luc_S
    Luc_S Junior Member
    Poland
    I'm almost sure it's a genuine HV charger from gen1 prius. Can't give a link due to PC restrictions, but I found almost identical unit (one digit of part number was different) on an archived auction in Poland.
    Edit: please search Generation 1 Prius Discussion for phrase NHW10 charger in to NHW11.
    #19 Luc_S, Jul 8, 2019
    Raytheeagle and edthefox5 like this.
  20. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Send it to me I'll figure it out pretty quick.
