What is Toyota shop time for cruise control lever replacement?
Discussion in 'Gen 3 Prius Main Forum' started by tcdp3, Jun 29, 2023.
  1. tcdp3
    tcdp3 Junior Member
    18 herrick st, nashua, nh
    After diagnosing the problem down to the actual on-off switch in the Cruise control lever assy, I am trying to determine if the cost of taking it to Toyota (vs. a smaller shop) for replacement is sensible. Does anyone know how many hours Toyota designates for the Cruise Lever replacement?
  2. JC91006
    16,479
    8,395
    This should be an easy 1 hr job. It's quite easy to remove the airbag and steering wheel.
    But most of the time, cruise control issues are usually due to the clock spring (non OEM)
  3. tcdp3
    tcdp3 Junior Member
    Thank you JC!
  4. Tombukt2
    Tombukt2 Senior Member
    8,966
    1,561
    Durham NC
    You should be able to knock that out with the right torx bit to get the steering pad off with the airbag in it. The rest will be screwdrivers 10 mm possibly an eight and I can't remember exactly it took me less than 18 minutes to have the steering pad and the steering wheel in my hand and walking into the shop with it I was doing something different the clock spring but very similar and this is actually the first time taking the steering wheel off a generation 2 Prius. Although off all other Toyota models I've taken the steering wheel off many times Corollas sienna vans all of that It's pretty much the same I don't think you'll be removing the steering wheel so you won't need the 19mm socket or any of that I think you'll have access to the cruise stalk with the pad off and can deal with that from there it should be a small screw and a push on and a plug-in I think I have one laying here apart I could send you a picture if that was needed I would never take this to the dealer for them to do remember when you're going to the dealer look at what's happening at your dealer that's all I can tell you You see mostly children walking around looking like they're lost service writers that are a little older than the children a lot of the technicians are still in the children age range etc etc you know pants hanging down halfway around there wherevers and all of that nonsense everybody's wearing basketball shoes etc etc I tend to take my vehicles if they ever do go to a shop to places that have people that look like they work in the auto business. What is that look It's not what I'm seeing at the dealer
  5. tcdp3
    tcdp3 Junior Member
    Thanks Timbukt2!
