What is your lowest M.P.G
Discussion in 'Prius c Fuel Economy' started by xerox6135, Jun 20, 2012.
  1. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Today was my lowest m.p.g temps around 97 and the ac on high. My mpg was 31. On average my trip is around 52.
  2. DKTVAV
    DKTVAV Active Member
    510
    101
    WOW, 31?
    I believe I've read a thread of someone with his very, very, very pregnant wife on the way to the hospital flooring when possible even uphill got 36. You got a new record.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Was it also a short trip in terms of distance? Mostly stop and go?
  4. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    On my regular commute, probably low 40s. But on a short jaunt down the street? Can be in the 20s due to lack of warmed up engine.
  5. akh02
    akh02 New Member
    63
    Oregon
    Hills are evil. I've had a few shorter (under 5 mile) trips in the 20mpg range because of hills. Some 5-10 mile trips in the mid to high 40s (again, hills). But longer than 10 mile trips have all been over 50mpg. Love this car.
  6. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Just wait until winter arrives. There will be reports of dipping into the 30's, often caused by extremely short trips with a cold engine. Thankfully, they'll be countered reports of unusually high MPG caused by traffic naturally driving slower due to seasonal change.
    Prius uses a surprisingly dynamic system. Just think what you'd be getting for MPG otherwise, not to mention emissions not being as clean.
  7. xerox6135
    xerox6135 Member
    170
    93
    michigan
    Yes it was a short trip 4.9 miles and got stop by ever light lol
  8. dellrio
    dellrio Im pretty much awesome
    281
    88
    37
    Des Moines, IA
    36 MPG on a 175 mile trip on Flat highways, low wind, 78 dgrees, Cruise set at 68MPH, ECO Mode, A/C off.
    38 MPG on the return trip with same stats.
  9. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Woah. That sounds really low. Were you able to stay mostly at 68 mph?
    Underinflated tires? Alignment probs? Changed you tires and wheels? Brakes dragging?
    On my Gen 2 Prius, on my previous commute, I could achieve a tank of just over 50 mpg if I kept my speed on the highway <70 mph for the whole tank.
  10. dellrio
    281
    88
    37
    Des Moines, IA
    It is low but according to the service Department - my car is fine and the MPG sounds "Pretty good". My 2010 Liftback did the same trip many times and easily topped 50MPG.
    Car only had 800 Miles on it when I started the trip - alignment and tires are good - 42PSI all around brakes are not dragging. I am at about 1300 miles now and my averages (i track this religiously) are 42City 37 Hwy 40 Combined. There is something definitely off with my specific car - but toyota will not look at the HSD system without a light on the dash - I took it in this morning and they said all is good and it must be my driving (not likely - i am an expereinced hypermiler - 40MPG out of my 2006 Scion XB, and 60's regularly out of the 2010 Prius)
  11. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    You definitely need to escalate this to corporate.
  12. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Check the oil level. Toyota dealers are a bunch of crooks and assholes who can't seem to figure out how to change the oil. Anyways, make sure the oil is below the "F" mark (but above the halfway between low and full).
    Try using cruise control for over 30 mph and see it that improves things.
  13. dellrio
    281
    88
    37
    Des Moines, IA
    With only 1300 miles It has not yet had an oil change, I did check the oil (thanks for the idea - I had not looked at that yet) and it looks good. Beside that - I don't let anyone do maintenance on my car but me - I don't trust anyone else to do the job correctly - especially a big time stealership.
  14. rjdriver
    rjdriver Active Member
    406
    167
    Rhode Island
    Yes, experienced a similar effect this past week with heavy air conditioning use, although not as dramatic as yours. My normal average is 55, but with temps in the mid to high 90s and air on all the time with highest fan setting, it dropped to the mid 40s. Watching the monitor, I could see very little battery feed to the wheels. It was all ICE with the battery concentrating on keeping the AC going. It takes a long time to cool off this car with temps in the 90s.
  15. managerman
    managerman Prius v Nerd
    228
    110
    Columbus, OH
    I know this might sound crazy. But I have found turning off the AC if the ICE is not running can help keep the MPG way up. (long stoplights, heavy traffic, etc.) AC on without ICE being on can deplete the battery at a rate up to 8 times faster than with AC off. (confirmed by scangauge)...
    -M
  16. ewaboy
    ewaboy Active Member
    693
    205
    Hawaii
    Winter? Yep - might get down into the low 60s or even high 50s for a couple days or nights...may even get some snow on Mauna Kea or Haleakala.
    Oh wait - you're in MN. One Minnesotan(?) I knew - when asked why he moved to Hawaii - said: "You've never lived through a Minnesota winter!" (And he was not smiling when he said this.)
    Just kidding:)
  17. skiarun
    skiarun New Member
    San Diego
    Hey M, how would someone turn off the ICE?
    I noticed you mentioned this up above.
  18. john1701a
    12,754
    5,245
    57
    You actually cannot; however, you can delay it from coming on.
    The A/C is electric. There's only a finite amount of electricity available. When you run out, the engine starts. Keeping cool by opening the windows can be more efficient at slower speeds.
    The heater gets heat from the engine. Hot coolant will feed it for awhile. But when it cools down too much (the threshold in ECO mode for the regular model Prius is 114°F) the engine will start. Keeping the blower on low helps draw out the no-run time. (Blocking the grille of the car does too.)
  19. managerman
    228
    110
    Columbus, OH
    I was referring to when the car goes into EV mode at stoplights, slow traffic, the ICE turns off on its own.
    -M
  20. bwilson4web
    15,511
    About 22.5 MPG 100 mph in the NHW11. The ZVW20 was similar at 100 mph but I didn't have my scanner setup to monitor the exact value. For planning purposes, 22.5 MPG is close enough at 100 mph.
