What just happened? (Uncontrollable engine surging)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 7Lowe, Mar 17, 2016.
  1. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    So, I was just driving home from work in my 2005 Prius (~78k miles) when the engine started surging erratically and uncontrollably. I don't know if this is the cause, but I hit a bump right as I was hitting the gas and so I wasn't surprised when it revved up at first. But, then I backed off and it kept revving. Then I took my foot off the gas and it was still revving and accelerating so I had to start braking to keep going the same speed.
    It kept erratically surging and then letting off as I basically kept braking at different levels to maintain speed or slow down when I could as we were coming to an intersection. The light turned red and I managed to get to a stop even though it was still revving, so I hit the P button and the engine calmed down. So, when traffic started again I slowly put it back in D and it surged again. We didn't move much before we had to stop again so I put it in P again. I noticed the battery icon was down to a few pink bars so I turned off the radio and air. Traffic started again and I put it in D and this time it seemed ok. I detected a faint smell that I think was probably from the brakes/tires being overheated, but it could've been something else maybe. It drove normally the rest of the way home.
    I'll have to see if I can find a shop here to take a look at it, but in the meantime does anyone have a clue what happened and is there anything I can do to prevent it from happening again?
    49,695
    maybe the bump hit something underneath, o2 sensor or something? no dash lights?
  3. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    There is no way anything could've hit underneath. It was maybe a 1" lip or something. Right when it started I saw some yellow indicator light, but I was so frantic I didn't really focus enough to see what it was and it went away pretty quickly.
    49,695
    maybe a wire fell off or something, but i think it would trigger a code. hopefully not your hybrid battery going south.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,808
    Clearwater, Florida
    You must not have owned your Prius for very long. The Prius has a very odd issue where if you hit a bump a certain way while you are on the brakes it invokes the slip indicator and it feels like the brakes have disappeared or the engine just surged. Its because you lose braking regen assist and are then on basic hydraulic brakes which are very poor. Pretty scary the first time.
    if you want to feel how bad the brakes are on your car get up to 65 miles and hour and put the car in neutral and try to stop. In neutral no regen assist. Which is a good thing to do now and then anyway as it cleans the brake rotors.
  6. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    I've owned it for about two years. What happened to me doesn't really sound like what you are describing. The engine was definitely surging as if it was full throttle or no throttle for a good 60-90 seconds until I got it into park. The brakes were working, but I just had to push them really hard to fight against the engine when it was surging to keep from accelerating.
  7. exstudent
    exstudent Senior Member
    2,214
    901
    Torrance, CA
    I guess you are the one person who lives to speak of unintended acceleration.
    Why dont you tell your local dealership, Corporate Toyota, & NHTSA (National Highway Traffic Safety Administration)?
  8. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    I don't think I'm the only one as I found other similar reports online. Some indicated the traction battery could be going bad and others said something about "resetting the delta history" possibly fixing it.
    I've only lived in this country a few months and I brought the car with me so I've never actually been to the dealer here. I'll try to get an appointment to go this weekend hopefully.
  9. exstudent
    2,214
    901
    Torrance, CA
    HV Battery going bad would produce codes and you would not have any power.
    "Resetting" does not work, as the ECUs will detect the failed module pair in a short period of time, if the HV Battery was truly bad.
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,235
    Madison, Wisconsin
    I know this may sound silly, but does your car have floor mats?
    Are they secured to prevent them from accidentally sliding forward and pressing the accelerator?
  11. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    This is exactly what I was about to post...
  12. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    It does have floor mats. They seem to be designed with a cut-out on the accelerator side so they don't even go under it. It can't really slide forward as the left side goes all the way to the back under the brake pedal. Also, it looks like both pedals are around 2" above the carpet and connected from above not through the floor. I tried to force it to slide and it won't slide, but I can pull it up and out.
    Thanks for the thought, but I am thinking this isn't the cause. The way it surged to basically full throttle and the zero throttle (since my foot was off the gas) several times makes me think it must've been some electrical/computer issue. I drove it just a bit early this morning before there was any traffic to see how it did. It drove fine, but I did notice that the instant fuel efficiency readout thing was reading the worst possible at 99L/km when I was stopped. So, the ICE was running even though I was sitting still and the battery readout was a little over half (It's below freezing, so maybe it runs the ICE for heat anyway?). As I started moving obviously it changed, but it was still really horrible and the little animation would show energy going to the battery when I was braking but none coming out of the battery at all. The battery level kept going up until about 2 bars were left and I was starting to get a little worried about what might happen if the charge got too high, but then I noticed it started showing energy coming back out of the battery and the fuel efficiency went back to normal. So, maybe I was just being overly paranoid this morning and maybe it was just something with the temp or something (I haven't ever driven it when it was below freezing before so I'm not sure if maybe it does rely more on the ICE for heat or anything).
    Maybe the thing the other day was just a glitch, but hopefully they'll be able to find a record or something of it when I get it to the dealer and they hook it up to their computer or something.
    If they find something I'll post back here and let everyone know.
  13. 7Lowe
    7Lowe Junior Member
    28
    Riga, Latvia
    I take back what I said before. It finally got warm enough to drive again so I took it on a long straight road with no traffic and floored it again. It only hung up for a second, but it did hang on the edge of the floor mat. Looking at it I didn't see how it would be possible since the floor mat has that big cut out under the gas pedal, but that's precisely why it was able to catch on that edge.
  14. bisco
    49,695
    aha! good call eric.(y)
  15. ericbecky
    4,379
    3,235
    Madison, Wisconsin
    I've done it myself in several cars, not just the Prius.
  16. bisco
    49,695
    try telling that to nhtsa.
  17. exstudent
    2,214
    901
    Torrance, CA
    Plug your VIN into the recall section of Toyota.com, to see if your Prius qualifies for the recall to shorten the accelerator pedal. If so, get his recall work done.
