What keeps the car from "flooding"?
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Aug 5, 2024 at 9:34 AM.
  1. Prius92
    Prius92 Member
    392
    97
    Iowa
    If you are having issues starting, does each time you turn the car on, the injectors activate, or will it only activate the injectors if it detects revolutions of the engine from the crank and cam sensors?
  2. Mendel Leisk
    38,788
    I’d “guess” it doesn’t become flooded (end up up with cylinders awash with gasoline).
    More backstory would be helpful. Repeated attempts at starting a reluctant Prius do tend tend to end up with no progress and a severely depleted hybrid battery.
  3. Tombukt2
    Tombukt2 Senior Member
    9,323
    1,628
    Durham NC
    You've got to go through the no start conditions kind of like a regular gas car for this portion coils plugs ignition stuff air is actually getting through the filter in the piping to the intake and so on That's just the way it has to be initially so what it seems like anyway.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,270
    5,965
    Columbia, SC
    I'm pretty confident modern EFI injects fuel only after the engine has started spinning.
