What kind of off-brand 12v batteries are people using?
Discussion in 'Gen 2 Prius Main Forum' started by wbs887700, Feb 25, 2021.
  1. wbs887700
    wbs887700 Junior Member
    74
    Can you post a link to the 12v battery you are using? I want to see what all is out there, I know there are multiple options but I only know of like 2
  2. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I got a BOSCH 12v BATTERY for the PRIUS at Pep Boys= Excellent battery!!!
    Ernie stires and uclabruins like this.
  3. lexidium
    lexidium Active Member
    298
    140
    manchester
    Bosch s4 022 type 155. You can get one off Ebay for around ÂŁ58 (UK)
    Batteries are not all the same size lugs
  4. Mendel Leisk
    41,473
    For international members, location "PA" is likely Pennsylvania, in the USA.
  5. Pioneerscot
    Pioneerscot Junior Member
    78
    Nevada
    Hmm, just a guess here, but since no one else posted an alternative to this Bosch battery that it must be the only one recommended ?
  6. Mendel Leisk
    41,473
    There's more "brands", for sure. Behind the scenes though, some of the brands may be the same apart from the label, there's not that many manufacturers.
    TGrracie and Pioneerscot like this.
  7. ski.dive
    964
    244
    The BOSCH 12v BATTERY for the PRIUS at Pep Boys=Is NO longer available
    Time to find an alternative battery...
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,048
    1,974
    NJ-USA
    I have had good experience with any AGM battery produced by East Penn manufacturing. They sell under the brand Deka, and supply AGM for Napa, Duracell, and others.
  9. Pioneerscot
    78
    Nevada
  10. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    I don’t even remember. I got mine at Costco thought.
    Pioneerscot likes this.
  11. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Mighty Max 35Ah - amazon.com - $85 roughly. Works great, Easy to modify minimally to fit.
  12. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    35 Ah might be okay for non-SKS but 45 Ah (or even 55 Ah) is better for the SKS Prius.
  13. Pioneerscot
    78
    Nevada
    Wow, so a mighty max 55ah is about 135 usd on amazon, this battery will work ?
  14. dolj
    dolj Senior Member
    8,450
    4,291
    As long as it is the right dimensions and has JIS pencil posts with the positive post on the right, preferably using AGM construction. At that price, I doubt it is AGM.
  15. JohnPrius3005
    423
    235
    Depends I'd say on what you are trying to achieve. In my case all I want is a 12V bat that I can reasonably easily connect to the car. I use 35Ah Mighty Maxes on my 4 Priuses. I bolt the car cables to the lugs on the battery - no pencil posts and I don't care which side the terminals are on. The MM fits in the Prius bat space, or I just lay it in the cargo bin. I disconnect the bat every time I leave the car for a few days (with the more junk cars I disconnect the bat every single time I park!!) I charge the MM with a Foxsur charger often. Basically any 12V bat works to boot the car computers which require minimal current - Walmart lawn mower bats, etc.
    #15 JohnPrius3005, Sep 4, 2023
  16. Pioneerscot
    78
    Nevada
    Ah, that's what i was looking to hear, just to boot things up for now and do some assessing of potential pit falls, thank you for that John
  17. Pioneerscot
    78
    Nevada
    And yes dolg its gel agm thank you, no pencil posts, I will deal with that for now though.
