What kinds of parking assist?
Discussion in 'Gen 3 Prius Main Forum' started by Cinemator, Jun 26, 2009.
  1. Cinemator
    Cinemator New Member
    The Netherlands
    During my test drive in the Prius III I tried out the parallel parking assist. I also noticed that when backing up into a parking slot (is reverse parking the term?) the reverse camera shows you the same overlay lines to help you park. However I didn't check if parking assist works in this matter too, so taking over steering. Does it? Or only for parallel parking?
    Best,
    Maarten
  2. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Yes, but it seems to be much more difficult to get the car and system lined up well enough to make it work.
  3. Cinemator
    The Netherlands
  4. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    Are you using the Prius V w/ ATP and mean Generation III Prius when you say Prius III?
  5. Cinemator
    The Netherlands
    Yes, 3rd generation.
    I'm in Europe so that models and packages are different. I have ordered a Prius 2010 "Dynamic" model which comes with HDD NAV and reverse cam.
  6. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    This is a 3rd Generation Prius, but they do not have a Prius V with AT outside of the US. In other markets, they models are mixed up a bit.
    Yes, it would be the same features that is found on the US version V with AT. (although it does not have all the US features, the parking assist is the same).
  7. Tideland Prius
    16,125
    I believe the lines are a European thing. I don't believe our reverse camera has the assist lines.
    IPA uses a computer to determine how to reverse into a spot. The lines are there for the human to use if he/she wishes to park on their own.
  8. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    I'm not sure we are talking about the same thing, but part of the process involves manipulating some lines on the screen. However, it doesn't seem to be necessary if you put the car in the right spot to begin with.
  9. Tideland Prius
    16,125
    I'm not talking about the box that the IPA uses to tell us the final position of the Prius.
    IPA models outside of NA also have "guidance" lines of red, yellow and green so you can judge how close an object is to the rear bumper as well as the projection of the car if you continue in that direction backwards. It's absent in NA models.
