What kinds of problems will a stolen cat cause (getting it fixed)
Discussion in 'Gen 2 Prius Main Forum' started by golfmk681, Jul 9, 2021.
  1. golfmk681
    golfmk681 Active Member
    262
    105
    los angeles, ca
    My cat was stolen and in the process they cut the O2 sensor. When I get the cat replaced with a OEM cat from Toyota will I need have issues with the O2 sensors working correctly and providing accurate reading?
  2. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    Presumably, you will also replace the cutoff O2 sensor with an OEM one at the same time as replacing the catalytic converter, so why would you expect it would not work as designed?
  3. golfmk681
    262
    105
    los angeles, ca
    Honestly I just feel ultra paranoid about spending so much money to get this car back to smog ready status and afraid it might not work.
  4. ETC(SS)
    6,544
    If you throw enough money at it.....it'll work, presuming your 310,000 ++ mile car does not have any other underlying issues.
    Since it's a G2 you CAN put a temporary straight pipe on it and drive it until; you get it smogged - whenever that is, and since there's a 5% chance that you're going to have a major earthquake there in the next little while (according to dot.gov) why take the chance?
    In fact....you can drive your car even without the straight pipe but I'd go under the car and make sure that the 02 wires aren't touching each other or something metal.
    Besides....unless you get a used cat installed at a 'no questions asked' garage....maybe even YOUR original used cat.....you might be in for a significant wait for your $1,000 OEM replacement since you "may" not be the only one in the market.
    Good luck!
  5. PriusCamper
    PriusCamper Senior Member
    11,065
    4,504
    Pacific Northwest, USA
    Only risk with the O2 sensor part of the theft is if when you started the car up those wires shorted out, which could damage car's ECU, but that's very rare.
  6. golfmk681
    262
    105
    los angeles, ca
    Hey guys just to clarify my car has an o2 sensors again. The guy who fixed mine with an aftermarket cat replaced th o2 sensor. I can’t pass smog however because the right levels aren’t being displayed by the cpu when they scanned my car. So I either replace it or get a replacement car.
  7. PriusCamper
    11,065
    4,504
    In California it's usually the visual inspection that shows Cat is not OEM, which leads to the conclusion aftermarket cat is not good enough. I've not heard of an aftermarket cat failing based on actual emissions. And if that was the case we'd all be more skeptical about aftermarket cats. If you have an opportunity for further clarification and documentation please let us know?
  8. golfmk681
    262
    105
    los angeles, ca
    Ok let me get the documents. I’ll also try again at the smog Wednesday morning. I’ll try warming up the car. Maybe that’s the issue. You post just spark an idea since it was 10 mins away from my house and I took the side streets. This is a good suggestion. I’m willing to try anything before dropping 3k on anything at this point.
  9. audiodave
    audiodave Active Member
    787
    268
    US
    I've used a aftermarket cat and the gas station I go to does not look under the car. 3 smogs so far. No problems.
    golfmk681 likes this.
  10. golfmk681
    262
    105
    los angeles, ca
    So you know guys thank you so much! Let me try it again and retest but I’m gonna drive my car for an hour before the smog test.
  11. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Did the "guy" doing the replacement use an OEM or Denso equivalent sensor?
    Did the repair come with a warranty?
    Usually the smog shop will tell you why the vehicle failed (visual, which OBD2 codes, gas cap, pressure test, etc).
    Do you have an OBD2 code scanner?
    Raytheeagle likes this.
  12. golfmk681
    262
    105
    los angeles, ca
    No no warranty. It’s a Facebook marketplace deal. He said he used OEM. I just needed my car back on the road so I didn’t expect anything more than that repair. I have a scanner and there is no codes popping up. No check engine since the install back in February.
  13. golfmk681
    262
    105
    los angeles, ca
    Ok update! I want to thank you “audiodave”and “priuscamper.” Your post clicked a light bulb in my brain that perhaps I needed to warm the car up by driving it around. Your replies made me think I need to retest. Anyway I went back drove the car 40 mins, and then went to the smog place. I passed SMOG. The readings were normal you two saved me from spending 3k on the car and security upgrades! Thank you so much.
    audiodave and Raytheeagle like this.
