What measurements do I look at when buying new rims?
Discussion in 'Prius c Accessories and Modifications' started by legoadan, Jun 14, 2015.
  1. legoadan
    legoadan Member
    166
    71
    Northern California
    2014 Prius c
    Can someone explain to me in some detail exactly what rims I need to buy so they fit right out of the box? Right now I have stock hub caps. When I buy rims I'll probably buy a new set of tires as well. What do I need to watch out for so I don't change anything tire dimension wise (except for weight, I know that's had to make it stay the same)??
  2. Mendel Leisk
    41,123
    What I'd do is plug your car in at TireRack website, see what it comes up with. Be forewarned, pretty much any rim is going to need adapter rings, to bridge the gap between the vehicle's hub protrusion and the hole in the alloy. That's the way with any of the one-size-fits-all aftermarket alloy rims.
    If you want to know the specific data, you can likely find it, or "reverse engineer" , by looking at the data of the rims TireRack suggests.
  3. mikefocke
    3,967
    1,792
    Sanford, NC
    Size of the rim, width of the rim, offset.
    Size is the simple 16" or 16" stuff.
    Width is the difference between the edges of the rim and determines the width of the tire.
    Offset is important because it determines if the rim will clear the brakes. Think of it as how far out or in from the center of the wheel the hub is.
    valde3 likes this.
  4. The Mouth
    The Mouth Junior Member
    91
    24
    Simi Valley
    DSCN0411.JPG For MPG purpose I would keep it close to stock as possible. Another thing to consider is the cost of buying new tires as apposed as to keeping the stock ones for your new wheels. Like me I decided to keep the stock 16 to save money and they fir my new wheels just fine. Wheel weight for gas mileage purposes the lower the better! I went with a little wider rim then stock and kept the stock tires. MPG is around 48. Not to bad!!!
    #4 The Mouth, Jun 24, 2015
