What might be worse than having recall work accomplished?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by snijd, Jul 23, 2015.
  1. snijd
    snijd DIY or die
    243
    52
    PNW
    Perhaps having it done badly? On 5 September 2013, I took my 2006 Prius to Lake City Toyota, in Seattle, for some accumulated recall work. The accelerator pedal was trimmed, a steering issue was addressed, and the inverter pump was replaced. I also asked whether the coolant would be changed as part of this work, since there is an allowance for new coolant in the work description. They said it would. Following this service, and for the past two years, the car ran without indications of high temperatures in the inverter, or any other anomaly.
    Today I changed the engine oil, and then the transmission fluid. As I prepared to add the ATF, I noticed something interesting: hose pinch pliers tightly holding the hose leading to the lower inverter cooling connection. A quick check showed there was no coolant circulation visible at the top of the tank. Removing the pliers immediately restored coolant flow. No one else had been under the hood during these two years, except myself. I had only changed the engine oil and air filter, so had not looked beneath the shroud, or at the area near the inverter and transaxle.
    Did I dodge a bullet? How could the inverter survive with essentially no functioning cooling system? The temperatures aren't always moderate here in the Pacific Northwest, and even in the high 90s it never misbehaved. I'd previously considered coming up with a simple system to monitor inverter pump functioning, but I don't think that even that would have caught this. The pump was running; it simply wasn't performing its function. Effectively, my pump was dead. Yet no fault was ever indicated. And might this have had any effect on economy?
    Since they obviously used the pliers to prevent coolant loss, is there any chance they changed the coolant? I think not.
    Finally, do mechanics at Toyota do tool counts? Or am I thinking of the kind of care taken in aerospace shops? Some mechanic must have noticed that his hose pinch-off pliers were missing soon after this!
    Lesson learned: Check everything the dealer touched. I could easily have taken the cap off of the inverter coolant tank and checked for circulation.
    Patrick Wong and Aaron Vitolins like this.
  2. Mendel Leisk
    40,586
    You should let the service manager know about the screw up, and have it noted in your records. Also, smells kinda stinky: their claim that coolant was changed, with the clamping pliers in place. Ask him nicely about that too? I'll bet there's more coolant change in your future; hopefully done right.
    I think it's good to name the place too. As long as you stick to the facts, good info to know.
  3. JC91006
    16,674
    8,519
    The coolant is suppose to be changed regardless if you ask for it or not. So basically they just don't do it
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    What's the point in complaining two years after the service was performed?
    I hooked up the ScanGauge to monitor inverter and engine coolant temps.
  5. Patrick Wong
    18,200
    6,493
    Responding to your question in the title - what if the recall work wasn't done at all?
    1. I agree that after two years have passed, its too late to complain - unless you want to make the argument that the pump wasn't changed since the clamp was in place, and you want it changed now, along with the SLLC coolant.
    2. How many miles were logged annually with the 2006, since September 2013?
    3. What is the longest trip that the 2006 took, since September 2013 - and what was the ambient air temp at that time? If you only take short trips during hot weather, the inverter cooling system is not really needed.
    4. Hey, you got an additional, free tool for your toolbox - unless you decide to complain, in which case you need to return that tool.
    5. If the inverter got hot enough, a DTC would have been logged. Hence I assume that the car was only driven for short trips at least in what passes for hot weather in your locale.
    Once, I found a 10 mm box/open end wrench left in one of my vehicles after service. At least it wasn't causing harm to the drive train.
    #5 Patrick Wong, Jul 24, 2015
  6. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Never trust dealers, their mechanics or their work. Never.
  7. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Trust, but verify before leaving the dealer...
    frodoz737 likes this.
  8. snijd
    snijd DIY or die
    243
    52
    PNW
    That sounds like what the dealer would say! ;-)
    This was on a Gen III, right? I never found a way to do that on a Gen II.
  9. snijd
    snijd DIY or die
    243
    52
    PNW
    1. Yes, it's always possible that no work was actually performed.
    Of greater concern is the impact on the drivetrain. When I drained the ATF yesterday, after 34,000 miles, the fluid was very opaque, and dark. This surprised me, as most owners have reported little change to the fluid for this kind of mileage, and at a third change. Does age influence ATF degradation more than mileage? Or does an elevated operating temperature have an effect? Wouldn't the transmission experience an elevated temperature, if the inverter coolant path was blocked?
    2. The car was only driven 9,000 miles since then.
    3. I didn't log trip length or ambient temperatures. The car never took a long road trip, though. So perhaps the longest trip was something like 100 miles.
    4. Yeah, I really needed that tool, too.
    5. I haven't run any diagnostics, but will do that today.
    Once, I found a large screwdriver rolling around near the flight control cables of my personal aircraft. But I wasn't happy to have an extra screwdriver! The mechanic just shrugged. Bad behavior isn't limited to auto mechanics!
  10. Patrick Wong
    18,200
    6,493
    Yes, the darkness of the drained ATF is troublesome, which is indicative that the transaxle was operating at elevated temperatures.
  11. snijd
    snijd DIY or die
    243
    52
    PNW
    Sent out a sample of the D6 ATF for a UOA. I guess this could be an extreme test of Red Line's formulation. Yeah, I know that D6 is no longer recommended as a sub for WS, but I have a lot of it around, and will keep using it until it's gone. And just maybe the Water Wetter in the inverter coolant didn't hurt.
  12. JimN
    7,028
    1,117
    South Jersey
    I had the ScanGauge plugged into my 2006 using some XGauges. At first I couldn't get the ScanGauge to work with the 2010 (other members with the same firmware didn't have a problem) so I returned it for a flash upgrade. After several programming attempts I got it working.
    The Feds are investigating GM & their dealers over recall work they claim was done on used car inventory that allegedly was not done.
  13. snijd
    snijd DIY or die
    243
    52
    PNW
    In case anyone is interested, it seems that I did indeed "dodge a bullet." Despite the lack of circulation in the inverter coolant loop, and the very dark color of the D6 ATF I drained, the UOA suggests that no harm was done, at least to the transaxle. The only area of concern was the TAN of 3.6. And probably the mere 9,000 miles since the hose was pinched off limited any adverse effects. So is this a testimonial to the quality of D6 fluid, or the value of Red Line's Water Wetter? Maybe not, but I'd submit that this is not adverse evidence to their impact on the transaxle and inverter. I intend to continue using Water Wetter, and have replaced the old ATF with D6.
  14. geekwithoutacause
    geekwithoutacause Junior Member
    63
    Phoenix az
    Yeah, never trust any work. That's why I try to do almost everything myself. When I did have to return cars to the dealer for work I could not do or was warranty work, I have found many pieces of tools left behind. Usually the better brand stuff too :)
    If they want it back you say it is evidence and will remain in your possession until the case is resolved. That should wake them up.
