What mileage could you achieve on this commute?
Discussion in 'Gen 2 Prius Fuel Economy' started by 2Girls&aGuy, Mar 1, 2012.
  1. 2Girls&aGuy
    2Girls&aGuy New Member
    17
    Washington
    Ok so I've been quite curious if I should or could be getting better mileage out of my newly acquired prius. I am seriously loving this car and have no problems with the current mileage I am getting now. But my curious mind wonders what if any mileage I'm leaving on the table.
    Here are my awnsers to the mileage questionnaire based on my 08 touring prius...
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    43.8 for a touring going 72mph cruise control is respectable. Drop the speed by 5mph and your mpg will probably get to 45mpg.
    370mi/week is 74mi/day assuming a 5 day workweek, and 37mi each way. At 72mph, that is 31 minutes. At 65mph, that is 34 minutes.
  3. 2Girls&aGuy
    17
    Washington
    should I expect to see a mileage gain as the weather starts to warm up, or is the mph that I am traveling mainly dictating my mpg?
    Also another thought I've been having is putting some LRR tires on this spring and converting the hankook's over to winter tires. That should benefit my mpg some yes? I'd be going from a 205/55/16 non LRR to a 195/55/16 LRR.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    drop your speed by 7 and you'll get closer to that 45 as 2k1toaster said... now.. drop a little more than 7mph, and you could get higher... when i towed my trailer around the s.f. bay area doing 55 to 60, i was getting about 50mpg.. which is way above what i usually get... speed is the key.
    you're getting good mpg for the speed you hold. i haven't been babying my car lately. a lot of short trips... keeping up with faster (not fastest) cars on the highway, and jackrabbit starts... i'm getting slightly below 40mpg... at times it's 40 to 45... if i baby it i can get more.. but.. shrug.. i like torque
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You will start to see a slight increase as the weather warms. One contributor is that for short commutes, the engine warms up faster. You don't really apply with this. The factor you will see is that summer fuel blends have more energy per volume then winter blends, so you get more energy per gallon.
    There is a graph around here someplace that shows the effect of speed versus miles per gallon. Basically 55mph is the sweet spot. You lose a couple average mpg for every 5mph faster you go.
    This is for a standard 30mpg car:
    Definitely help. You wont "save" money by buying two sets of tires, but you will increase your average mpg.
  6. 2Girls&aGuy
    17
    Washington
    well it's nice to hear that my numbers are at least in the realistic realm of where they should be. It's just crazy to see all these signatures on the forum with 50+ mpg. I just wanted to reassure myself that my conditions just don't permit that number.
    I agree with you 2k1 that I'm not saving money with two sets of tires, but around these parts its beneficial to any driver to have a dedicated winter tire. The commute can get quite sketchy in the winter months.
    One thing that I have found strange is my miles per tank, I am typically putting in right at 8 gal of fuel per fill up and that is with one pip showing. I would have thought that the tank would hold a bit more than that. I think that this alone has been my one gripe about the car so far. I can't make it a full 5 days without having to fill up.
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Conditions permit, you just have to slow down.
    If you had a tank, then maybe. ;) You have a flexible fuel bladder that expands and contracts with temperature, pressure, mood, whatever.
  8. 2Girls&aGuy
    17
    Washington
    yes I assumed that much as well 2k, I just hope my bladder expands a bit as the temperature creeps up this spring. I'd sure like to squeeze in more than 8gal at a time.
    As for conditions permitting I guess I shouldn't have worded it that way. Of course if I slowed down to 55 my mpg would be much better, but I'm not going to do that.
    One thing I have thought about for a while now though is getting off an exit earlier on my commute home and traveling the old highway for an extra few miles. This would surely benefit my mpg. Posted speed on that highway is 55mph, If I was really serious I could travel that highway all the way to work.
  9. fuzzy1
    10,172
    It will improve with the weather, but likely by a smaller proportion than commuters going shorter distances at lower speeds. This graph shows my seasonal variation, but I average half your commute distance at half your average speed, in a newer generation car.
    I see a quadruple whammy in those tires. Non-LRR costs fuel. 205 width costs fuel (see F8L's frequent posts on this as he swaps between wide and narrow, depending on his mood.)
    And since both sizes are the same 55% aspect ratio, the 205s will have a larger rolling diameter, requiring adjustment of both the speedometer and odometer measurements. Without adjustment, the 205s will cause you to drive faster than you think, costing extra fuel, and produce a lower odometer reading, producing an artificially low mpg calculation.
    But remember that Prius is not a standard car. Bob Wilson's mpg vs speed graphs show a much different shape. Prius has no 'sweet spot' or 30-55 mph plateau.
    That chart shape isn't even right for the manual transmissions in my household.
    Lower speeds, other different conditions, plenty of hypermiling skills, and numerous Gen3s in the mix.
    It does hold more than that -- usually. But the Gen2 bladder is infamous for inconsistencies, and you probably don't want to get stranded by the problems and short tanks it is known to produce. I'd have no qualms about going a whole week on a no-bladder Gen3.
  10. 2Girls&aGuy
    17
    Washington
    Good information fuzzy, was the stock tire size on the touring prius 195/55 or 185/55?
  11. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    I see two things that haven't been mentioned (or maybe I missed it):
    74'F is a nice cozy temperature, fine if you're padding around the house in your slippers and bathrobe, but in a car (assuming you're wearing a jacket and good shoes for the weather), you could probably keep it at 68-70'F and still be comfortable. Heating up the car when it's cold outside takes a hit on your first several miles (or until you get on the freeway, whichever comes first), since the car can't turn off at lights or when coasting. I have a short commute so the effect is magnified for me, I'm not sure how much of a difference you'll see, but it will be something.
    You use cruise control in rolling hills. If you're serious about fuel economy, you can do better by driving it yourself. Slow down a bit on the last bit of the incline, and recover your speed on the drop. That can give you at least another 1 mpg (more or less, depending on what your hills really are like, I know Washington state has a lot of variation in terrain).
    But in the end, you're not far from your goal. 43.8 for the weather and conditions is reasonable, you'll easily get 45 when it's 60'F outside.
  12. 2Girls&aGuy
    17
    Washington
    lol, I like that nerfer. No I'm not padding around in my slippers when I'm driving to work. I will try and drop the temp a few degrees and see how that goes. Any input as to running the AC verses not? I don't understand why you would run the AC in the winter. I guess I just don't understand how the auto AC funtion operates.
  13. babybird
    babybird Member
    117
    44
    Colorado
    One thing about the Prius, it has a humidity sensor in the cabin. I'm not sure exactly how this affects things, but my guess is that it runs the A/C less if the air is already dryer if it's not needed to keep the interior cool. I know when I run the climate control in auto with A/C on in winter, it barely runs at all (but it does run a tiny bit here and there). As the weather warms up, it runs more. The Prius A/C is electric, and it's also a special type of compressor based on a variable speed industrial compressor design. This allows the car to run the pump at only the intervals and speeds that are actually required to meet your temperature demands, which is completely unlike most cars. I've tried running with A/C on and off this winter in my '08 touring, and I've never seen any difference in mileage from it. In the summer there is a small to significant difference.
    When I've had similar driving conditions here in CO to what you describe, my mileage is right in line with what you're getting in yours. It looks perfectly normal to me-- I've had my car since August and have put about 16,000 miles on it so far. I deliver pizza in it 5 days a week, so I have tons of experience with it now.
    When I drove it from CO to AZ shortly after buying it and the temperatures were still 50+, and I was driving at interstate speeds with cruise set at 69, 74, or 79 MPH, I averaged between about 44 and 48 MPG on every tank (about 2,000 miles), so you can probably expect to hit around 45-48 MPG without altering your driving style at all come warmer weather. Warmer weather also gave me more consistent fill-ups because the bladder seemed to have less variation than in colder weather. You may yet be able to reach your 1 tank per week goal.
    That said, if you can adjust your commute and driving habits just a bit, learn how to maximize pulse & glide over your commute, and drop your top speed down, you should be able to get into the 50s pretty easily. If I stay below 60 MPH in warm weather, I average 52-58 MPG doing those things alone. But only if the temp is warmer and I avoid things like cruise control on hills, too much highway merging, too much passing, not keeping an eye on my consumption screen etc.
    One thing that I've had to adapt myself to, I'm used to driving by ear but you can't do that with a Prius and get your best mileage. I've noticed that under many circumstances, I can let my foot off the gas pedal quite a bit (under light to light-moderate acceleration) without negatively affecting my acceleration noticeably. The engine revs lower, but my rate of acceleration changes very little in some cases-- that helps increase my mileage without a sacrifice. It takes time to develop that "butt feel" of when letting off the gas helps vs. when it hurts mileage. It's taken me around 15,000 miles in 6 months to really start to get the feel. And it doesn't work that way all the time, only in specific circumstances.
    You can start practicing that by watching your instant MPG on the consumption screen-- try to aim the instant MPG to between 1/2 to 1 MPG per MPH (so MPG between 25 and 50 MPG while accelerating at 50 MPH, 20-40 MPG accelerating at 40 MPH etc.). Keeping your MPG within that range while accelerating will give you conditions where you can develop that butt feel for when you can let off the gas a bit without lowering your acceleration rate and improve your mileage. For me, I can add an extra 4-7 MPG by doing that-- at least until I lose most of it again by getting ticked and passing someone or trying to merge into heavy highway traffic. ;)
  14. 2Girls&aGuy
    17
    Washington
    good stuff babybird, thanks for taking the time to post. Since I posted this up I have made a few minor changes to my commute. I dropped my cruise control set speed down to 68 on the freeway and have been taking an exit 5 miles earlier than normal on my way home thus giving me an extra 5 miles of 50mph hwy driving. This alone has netted an increase to above 46mpg, still in cold conditions of course.
