What Mode should i use to go up/down the hill...
Discussion in 'Prime Fuel Economy & EV Range' started by prius4owner, Feb 26, 2018.
  1. prius4owner
    prius4owner Member
    84
    30
    Southern California
    I live on the hill. It is about 5 miles drive all going up the hill.
    My question is what mode should i use to drive up and down the hill for my daily commute.
    Any strategy to maximize the MPG ?
    Also, i noticed that it charge about 9% battery when i go down the hill for work.
    Thanks
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    B mode all the way down.
    prius4owner likes this.
  3. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    The traction battery is charged already as you go down the hill, so enjoy, the ice will come on in the first 5-10 minutes, just bear it, as you go about your drive save some traction battery to get back up the hill, if you have 15miles left, use the ice for steep slopes and the traction for less steep, just assuming you are driving 40 miles on your commute, D is unnecessary driving down, you're already charged.
    If the five miles uphill is at 55 mph, save the 20-30 traction miles for the uphill drive.
  4. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    If the up hill is at the beginning of the drive, use EV Auto.
    If the down hill is at the beginning of the drive, and like me, you fully charge the battery, since there is no other option, use EV. If you want to stop regen from starting the engine, because the battery is already full, the only suggestion that I have heard to keep the engine off is to use Neutral and brake during the down hill parts until you have used some of the battery capacity, then EV.
    I have used B mode, on occasion, but it tends to bring the engine on more easily. I have used B mode around town, and it prevents the engine from turning off at stop lights when the battery is in HV mode(bottom 1/3). Use B mode with discretion.
    For mountains and some hills, HV up, EV down. Regen can add 8-9 miles of EV range per 1000' of elevation drop. EV does not climb mountains efficiently.
  5. muleman
    muleman Junior Member
    56
    48
    rochester ny
    I love the neutral roll.
  6. Prime8
    Prime8 Member
    Oregon
    2020 Prius Prime
    I finally got a chance to use the neutral roll today, and the ICE successfully failed to come on. This saved me the fuel of the warm up since the trip was short.
    muleman likes this.
  7. Wuzki
    Wuzki Member
    101
    34
    los angeles
    Turn on ev auto mode for extra power. If not hv mode is best for uphill. I don’t see any good mpg for going up hill unless you had ev mode on.
  8. CraftyCoder
    CraftyCoder Member
    48
    65
    Washougal, WA
    2018 Prius Prime
    I did some ROUGH calculations on strictly the energy used to drive your roughly 3600 pound car up a hill. Ignoring all inefficiencies(which is a major over simplification), you will still use about 1.4 Kwh for every 1000 feet of elevation gain.
    Since this is about 20% of your available charge(6.5 Kwh), it translates to about 5-7 miles on a level surface. So as a rule of thumb delete about 5 miles of your range for every 1000 feet of elevation gain. Of course, you get much of this back on the down hills.
  9. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    Well, if I were you, I'd program the charge at home in such a way it will not be completed at the time you usually leave, i.e. if you leave at 0730 am you could instruct the car to complete the charge by 0815 am. This precaution should leave enough room in the traction battery to complete the charge going downhill.
  10. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    When you leave home, only keep partial charged. When you climb the hill, keep at lease 5 miles electricity.
