what oil filter and washer
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hotbrass, Oct 21, 2009.
  1. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Where is everyone getting their oil filters and drain plug washers from for the 2010 Prius? Using Mobil 1
    Best price?
  2. zjkozlica
    zjkozlica New Member
    Chattanooga,TN
    Hi I orderd my from ebay and I have ask them to send me washer to. you have to wait to they send you total price, I think washer is 1.09 a pc. Store is Koons Arlington toyota, Just tipe this and is gone to showe and they have free shiping New OEM Case of 10 Toyota Oil Filters (04152-YZZA6) Good luck.
  3. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    See what it comes out to with tax after buying the oil, filter etc for do it yourself oil change. I had mine done at Toyota 2 weeks ago and with the 5 quarts synthetic 0W20 filter and everything else with was $51 with tax. I thought it would be more, but it was only $10 more than I could have done it myself... Having them do it for that price may be worth it to many people.
  5. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    I would do it myself even if it cost a few dollars more.
    Some people are just that way.
  6. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I had all intentions of doing it myself but I was in the area of the dealership and decided to just have them do it. I was pleasantly shocked at the relatively low price for having them do it. Plus I, like many I'm sure, have difficulty making the time to do it myself...
  7. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    Good timing. Just yesterday, I stocked up.
    Element Kit (04152-YZZA6) = $5.15
    Plug Gasket (90430-12028) = $2.09
    Also, don't forget about the oil-change document for the 2010.
  8. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Did you buy these locally? The price for a filter at the dealer is about $10 here.
  9. john1701a
    12,754
    5,245
    57
    Yup. I just happened to swing by the dealer (Burnsville, MN) when they were having a special.
  10. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    Thank you the great and informative document!
    Just FYI,
    The JP maintenance manual recommends following step when we remove the filter cap.
    - Loosen the filter cap four turns, then locate the index rib(*2 on the following picture) at the top or bottom for oil draining from the cap.
    Ken@Japan
  11. datrays
    datrays New Member
    39
    Harrisburg, PA
    Is the purpose of this so the oil doesn't drain all over the place. How would that help if *2 is on top?
  12. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    If I remember correctly there is a rib that will cause the oil to stick to and drain from the rib as opposed to running from one side then the other. Not real important, just neater, less mess. I believe there are two ribs, 180 deg from each other
    Of course I have been wrong before.
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    You are correct, there are two drain slots as shown in Ken's drawing (*2), they seem to do the job and most of the oil comes out of the cap when you locate one of them at the bottom. As it says, the cap needs to be loosened 4 turns before it can drain.
  14. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    We can see the drain slot on the screw thread of the cap from the John's document page-12.
    Ken@Japan
  15. Mr. Bill
    Mr. Bill Generation III
    86
    222
    Dunedin Florida
    Got my filter from 'One Stop Auto'
    You need to go to a full service auto parts store (NAPA / etc) - they needed to look it up on there computer and get me the filter.
    The o-ring is included with the filter (you may want to verfiy)
    Check you my Standard work - step by step change procedure including pictures if you are interested.
    Also - I use Mobile 1 ..... second to none for overall performance and results.
    I hope this helps - Bill
    (wrenches - 64mm for the filter and 17 mm for the oil pan)
    :rockon:
  16. tumbleweed
    4,067
    687
    Eastern Oregon
  17. triumph1
    triumph1 Member
    275
    Second to none? I don't know about that......
