Featured what other PHEV have "CRG" or charge mode?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by The Big Sleaze, Aug 24, 2022.
  1. The Big Sleaze
    286
    63
    'frisco
    2020 Prius
    Two Eco
    My doctor says his new BMW PHEV doesn't seem to have "CRG" mode and only charges with cord.
    Can this be true?
    What is story on other PHEV?
    "CRG" is said to a "hidden feature" (but its my fave) and none of the idiots at several Toyota dealerships knew it existed even when asked directly.
    I can't believe Toyota could have some Patent because many of the very first cars were fully EV only, so I'm sure every variation of EV and PHEV, etc was Patented by 1900. IIRC there were golf carts that were basically PHEV with both ICE and forklift battery with the idea you could operate unlimited or keep it quiet if golf decorum required it....but don't see any such rig for current sale. Many gas powered carts seem to have electric starter motor simply connected to ICE and you go from stop to forward and it starts as EV then ICE kicks in. Maybe its a centrifugal clutch like moped, but connected going the other way.
  2. Tideland Prius
    16,128
    Outlander PHEV and I believe some of the Ford Energi models.
  3. austingreen
    austingreen Senior Member
    13,569
    4,107
    Austin, TX, USA
    What is CRG?
  4. The Big Sleaze
    286
    63
    'frisco
    2020 Prius
    Two Eco
    short for "Charge" vs "EV" for "electric vehicle"
    Prime as a button to switch from EV to "normal" mode, and "normal" is what happens when battery is at IIRC 10% or less and engine starts and will cycle on and off. In "EV" an EV light shows, in "normal" light goes off.
    However....if you HOLD that button a "CRG" light will appear, and the engine will stay on in most normal driving (will shut off in Neutral or decel or down hills) and will re-charge the battery (takes about 30miles of freeway to fully charge). This allows you to plan ahead and use EV mode without bothering with charging cord. For instance, I got a fast morning commute but nasty evening commute in bumper to bumper. I'll make sure I've got good charge so when crawling along I'm in nice quiet EV mode and not engine always on and off every 2 minutes. "CRG" while in PARK will keep engine on and charge battery.
    In "normal" the engine will tend to keep the battery charge level same and cycle on and off automatically. EV is default mode when car is turned "on" to start driving unless batt is low then will be "normal" and drive around and battery will remain very low.
    Prius Prime Amazing Hidden Feature
    Jan 16, 2019
    1.4K
    Dislike
    Share
    No idea why this is "hidden". IMO its the best feature and I wasn't going to buy a Prime until I got confirmation it existed.
  5. bisco
    49,399
    i think chevy volt was the first with this feature. they called it hil climb mode or something.
  6. Tideland Prius
    16,128
    FYI, the Prime shows CHG not CRG.
    drash likes this.
  7. bisco
    49,399
    maybe toyota hid it because they don't think it's a good idea to use it too much
  8. The Big Sleaze
    286
    63
    'frisco
    2020 Prius
    Two Eco
    interesting, it does charge up battery much faster than even 220v in about 1/2 hour on freeway which is little longer than it takes to fully drain a full batt.
    I was thinking its "hidden" for political reasons, like they don't want people asking questions like "if it uses the ICE to charge the battery, why is the Govt giving away all that money?"
    austingreen likes this.
  9. bisco
    49,399
    hey, anything's possible. they do have a nervous legal team
  10. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    They do advertise their hybrids as self-charging and so I guess that includes their plug-in hybrids.
