What parts in the Gen II are shared with the Corolla?
Discussion in 'Gen 2 Prius Main Forum' started by TheEnglishman, Jun 28, 2013.
  1. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    I've heard the suspension is, but what else? I'm just curious.
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Maybe some switches and interior trim but that'll be able it. Even the engine in the Prius is specific to the Prius. It might be a 1.5 but that's about as near as it gets to any other 1.5 Toyota engines.
    Without going into full details, the engine in the Prius (gen2 and gen3 and maybe the gen1) works in a completely different way to any other petrol engine in a production car today. It lacks power, hence a 1.8 only gives 100bgp, but gives great fuel economy. The electric motor takes up the slack, almost like a turbo, in a very vague sense of the word.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Not entirely true, Grumpy.
    There are several interchangeable engine parts for the Toyota/Scion 1.5L engine family from 2001 to 2009. In fact, the 1NZ-FE engine used in the xA, xB, and Yaris is a variant of the Prius 1NZ-FXE engine.
    Toyota NZ engine - Wikipedia, the free encyclopedia
    So, the Gen II Prius gasoline engine isn't quite as "specific" as you believe it to be.
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    (I know, I was just trying to keep it simple ;) )
    I was trying to draw attention that one can't simple remove a Prius engine and replace it with a Yaris one, or vice versa.
    All manufacturers use multiple parts from their 'parts bins' and I'm sure the Prius is no exception, but you can't just lug a non Prius engine in as a quick or cheap fix.
  5. bisco
    49,617
    what about the wheels?
    GrumpyCabbie likes this.
  6. kammssss
    kammssss Member
    287
    86
    SoCal
    Probably the engine, which is why they last so long...:)
  7. Tideland Prius
    16,172
    The engine, as stated above, is a 1NZ-FE engine (FXE in hybrid form) and it's based on the 1.5 litre engine found in other Toyota subcompact vehicles (Echo/Yaris, xB, xA and even the Gen 1 Prius).
