What rim covers/hub caps would fit my tires?
Discussion in 'Prime Main Forum (2017-2022)' started by Joe Wall, Jan 5, 2025.
  1. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    I have a 2017 prius and bent the aluminum rim so I replaced the front 2 to steel rims. However the orm rim covers don't fit anymore. Any advice on finding one's that will?
  2. Mendel Leisk
    41,488
    What are the steel rims, are they Corolla rims, or some generic? If they're from a Corolla there's very likely a compatible Toyota cover. Obviously not going to match the alloy wheel covers though.
  3. Joe Wall
    Joe Wall Member
    237
    51
    Wisconsin
    Standard I'm pretty sure
  4. Mendel Leisk
    41,488
    I’d look for a replacement for the one bent rim, salvage, eBay, Craig’s List. Or if the bend is minor, there’s places that can mount it on a lathe and restore, for under $100 typically. Depends on your OCD level though.
    for our snows I had Corolla steel rims for about a decade, with just makeshift centre caps. When the snow tires aged out, I had replacement set of 2012-2015 Prius Plug-In rims on hand (purchased from Priuschatter for $400 USD), swapped to them. They’re a nice looking rim, cover not needed.
  5. talonts
    talonts VFAQman
    468
    76
    From what I've seen from perusing online auctions for Prius, the 10-spoke rims on my 2021 Prime are the same that I've seen on a 2010 Prius. So they should be plentiful in boneyards by now, even in Canada.
