What Scan Gauge outputs do you monitor?
Discussion in 'Gen 3 Prius Main Forum' started by 5 Speed, Feb 5, 2017.
  1. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    Being relatively new to the Prius what Scan Gauge parameters do you find important to monitor? I have the engine temp, state of charge of the hybrid battery, voltage of the 12V system, and mpg on my main screen.
  2. gliderman
    gliderman Active Member
    751
    223
    ICE coolant, brake friction, cabin temp, ICE rpm.
    glutaman likes this.
  3. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    I originally set the ICE coolant temp and it seemed to never change and was always quite cool. What is the normal operating range of the ICE coolant?
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    RPMs, coo!ant temp in F, intake air in F, and instant MPG (I get average MPG on the dash)
    RPMs at a given speed correlate to MPG, and every car prior to the Prius was a manual and I miss it.
    Coolant should be 195F once warmed up.
    Air temp in my Gen 2 made me feel it was over heated in MS in the summer, the v does not rise as far.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    HV Battery Temp2
    Cabin Temp
    Coolant Temp (Winter)
    HV Battery Fan Speed (Summer)
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Inverter coolant temp, ICE coolant temp, RPM, instantaneous fuel economy.
  7. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Battery discharge rate (AMP); coolant temp; instantaneous mpg (MPG); segment mpg (AVG).
  8. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    ICE coolant temp
    HV battery temp
    RPM
  9. JoeM(GA)
    JoeM(GA) Member
    40
    35
    Atlanta,GA
    Instant MPG
    12V battery voltage
    Water Temperature
    RPM's
  10. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    I use 2 scangauges:
    #1: RPM, battery current draw (amps), battery state of charge, friction brake sensor
    #2: engine coolant temp, mpg for current drive, traction battery temp 2, a/c current draw in amps
  11. Mendel Leisk
    38,717
    I disconnected mine about 18 months back; there's a possiblity it was causing a problem at the OBD port. But what I used:
    Pretty much constantly:
    Accumulating mpg per trip
    Instant mpg
    Coolant temp
    The last I would juggle between:
    coolant temp
    hybrid battery temp, at sensor #2 (with an XGauge)
    AC compressor wattage (Ditto) (to see when AC's running)
