What Secures Rear Plastic Quarter Panels to Body?
Discussion in 'Gen 2 Prius Main Forum' started by jimolson, Oct 17, 2018.
  1. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    Last winter my wife backed into a mound of hard snow, damaging a rear plastic quarter panel. By this I mean the soft plastic "bat wings" of the painted rear bumper that wrap around the sides of the vehicle.
    As result of the damage, this rear quarter panel is loose. It flaps noisily in turbulent air when the Prius gets passed by any large truck.
    Does any reader know what kind of plastic fastener secures these quarter panels to the steel body?
    I have pulled the bat wing outward, looking for a hole or slot in it that passes the fastener, but I see none.
  2. PriusCamper
    PriusCamper Senior Member
    13,438
    5,424
    Pacific Northwest, USA
    I only dealt with this once, but if I remember correctly it's held on by little clips that can easily pop off... So perhaps your clips were left behind at the place of the collision?
    The least expensive fix is to go to a pick-a-part junk yard that has a wrecked Gen2 Prius and pull off that part of the car and grab some clips, as well as learn how it clips and unclips before you apply the fix to your own car.
  3. audiodave
    audiodave Active Member
    800
    272
    US
    There's clips and one screw at the front of it. That screw area breaks and leaves only the clips. Pop it back and you'll see black plastic rib that's secured to the car. That piece needs replacing and part number is on it. Screw might be gone too. Look part number up on eBay. I found a aftermarket for under 20 shipped.
  4. audiodave
    800
    272
    US
    It's the parts between the salt lamp. Old sale so I can't pull it up. Screenshot_20181017-135932.jpeg
  5. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    I just watched a very good YouTube video showing the removal of the rear bumper. Each bumper bat wing is secured to a molded horizontal strip attached to the steel body under the bat wing. The method of securement is two-fold: loops in the bat wing's edge are grasped by claws molded into the horizontal strip. And lastly there is a self-tapping screw with a 10mm head.
    The screw can be seen if you look upward from the wheel well.
    Thanks for the quick reply, Prius Camper.
    Jim Olson/Indianapolis
  6. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    Great answer! Thanks. Jim O lson
  7. jimolson
    jimolson Member
    162
    63
    Indianapolis, USA
    Thanks, Audio Dave. Just ordered one on EBay.
  8. PriusCamper
    13,438
    5,424
    How did the salt lamp work out for you? Always wanted to buy one, but never pulled the trigger?
    James1964 and Skibob like this.
  9. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Hahaha I was thinking the same thing :whistle:
    PriusCamper likes this.
  10. audiodave
    800
    272
    US
    It's a cool lamp, not sure it's pulling anything out of the air though. Lol
    Super cheap on eBay.
  11. tf4624
    tf4624 Active Member
    527
    51
    It’s plastic tabs. Use a screwdriver to pull the tab out. Then pull the entire plastic tab out
    Bat cave
