What should i believe???
Discussion in 'Gen 2 Prius Main Forum' started by Clubford00, Jan 16, 2008.
  1. Clubford00
    Clubford00 New Member
    93
    Buffalo Grove, Ill.
    Today i was messing with the newly installed scanguage II and i set it on mpg and the dash readout and the scanguage readout was way different. the dash said at 50mph flat and level was about 48 the scangauge said 34 WOW what a difference. Anyone else have this happen?
  2. prim2
    prim2 Junior Member
    64
    Toronto
    Have you completed the full setup and calibration of your ScanGuage as detailed in the manual? If not, go with your Prius' display.
  3. diamondlarry
    diamondlarry EPA MPG #'s killer
    559
    Elkhart, IN
    I would have to ask the same question as prim2. If you haven't properly calibrated the SG2, it may still be set to the default of a 3.0L engine which would give a reading that is way lower than the FCD.
  4. Clubford00
    93
    Buffalo Grove, Ill.
    Nope, all done to my cars specs
  5. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    I would suggest that you use pen and paper, and track all of your gas fillups and your mileage, and do the math.
  6. Bob64
    1,540
    92
    Virginia
    I'd double-check the engine size again... Theres a chance you forgot to save or the SG "forgot" your settings...
    You wouldn't be displaying the trip mpg data would you?
  7. Clubford00
    93
    Buffalo Grove, Ill.
    im pretty sure i did everything right but tomorrow ill double check it again. Supposed to be a high of +7 here tomorrow with wind chill in the - 10 range brrrr. im so glad i work outside !
  8. Clubford00
    93
    Buffalo Grove, Ill.
    I dont know what buttons i hit to screw it up but i reset all the defaults then did setup again and now its fine. Duh !
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    That can also produce inaccurate results due to the bladder in the gas tank
  10. richard schumacher
    7,663
    1,040
    United States
    "This sort of thing has cropped up before, and it has always been due to human error." :_>
  11. Doc Willie
    1,717
    142
    Out there, somewhere
    Even using the recommended calibration procedure, the SG can still be way off. (After 6 months, I still haven't gotten mine right).
    There is a spreadsheet on CleanMPG.com that will get you closer, if you can figure out how to use it.
