What should i take into account when buying a used batter 05 prius
Discussion in 'Gen 2 Prius Main Forum' started by Delacerda.diegofelipe, Aug 31, 2015.
  1. Delacerda.diegofelipe
    san francisco
    hello prius people. I am a self sufficient college student with very limited funds. i bought a 2005 toyota prius about 3 months ago at 65,000 miles and have put 15k on it so its at 80,000 miles now. just recently my cars emergency hazard turned on on my dash. i took it to midas for an oil change and to get all the codes read to me.
    the codes read as follows: ( P300 BATTERY CONTROL) (B2799 IMMOBILISER MALFUNCTION) (p080 REPLACE HYBRID BATTERY PACK) (c1241 Low Battery Positive) (B2775 INTERIOR VEVITICATION)
    (B1421 SOLAR SENSOR)
    i started another thread and was told i need to replace the main battery first and foremost.
    i found a few used ones online for around 700 without the replacement included. i would really appreciate any feedback or guidelines i could follow when buying a battery. my car maxes out at about 20 mph and im not comfertable driving it unless absolutely neccesary. also does the battery have to be from the same year as my car (I.e a 2007 battery for my 2005 prius would work?)
    thank you anyone who can help i super appreciate it
    49,492
    warranty my friend, reliability of the seller and ease of returning it for another. any year from '04 to '09 is fine. i think there is even a way to use gen III modules. (2010-2015)
    have you tested the 12 volt battery?
  3. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Battery out of warranty time factor
  4. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Check 12 volt baattery may be cause some of the codes
  5. dat2109
    dat2109 Junior Member
    26
    Carolinas
    You can use any battery pack from the 2004 - 2009 generation 2 Prius.
    You will need to ask yourself how long you plan to own the car. Unless the used one you are buying has been recently replaced with new modules, its not likely to be a long term fix. If you are only looking for a few months or so it might be the right solution for you, make sure you have the warranty for those few months. My understanding is many people dont make it out of warranty before problems strike again if the modules are older.
    Delacerda.diegofelipe likes this.
  6. borrowedcarbon
    borrowedcarbon Junior Member
    16
    23
    I agree that you should test then probably replace the 12V battery. Then see what codes are left.
    Check out Toyota Prius: How to Check the 12v Auxiliary Battery Health - PriusDIY.com
    For the HV battery I'd go a place like Battery4Prius.com in the SF area and they'll give you a warranty with a refurbished battery. It's about $1100 - but this is one of those expensive problems to fix.
  7. daisy555
    daisy555 Senior Member
    1,379
    579
    CT
    First thing to do before buying a battery:
    Sorry I can't see where you are from while on my phone.
    By any slim chance are you in a CA carb state that adopted laws in 2004?
    Was car originally purchased in a CARB state?
    Slim chance car was originally purchased in last few months of 2005 but worth a chance looking into it. I know someone who just had 2006 hybrid battery replaced under warranty in CT despite law not taking effect until 2008
    Darn...such low miles on your 2005. Hope you can find good, inexpensive replacement.
    #7 daisy555, Aug 31, 2015
  8. kenoarto
    kenoarto Senior Member
    396
    Chicago, IL
    12v first. Then the expensive stuff.
    Salvage09 likes this.
  9. dolj
    dolj Senior Member
    7,657
    3,868
    Wellington, New Zealand
    Actually, in your other thread you were advised to replace the 12 V battery (you know, the small 12 V one in the right rear fender) first and foremost.
    2005 toyota prius. Emergency light on dash. codes found please help! | Post #5 | PriusChat
    Why start another thead asking the same question? Were you hoping to get different answers?
    #9 dolj, Aug 31, 2015
  10. JC91006
    16,482
    8,400
    is this car salvaged?
  11. Delacerda.diegofelipe
    san francisco
    your right im sorry. i did happen to get quite a few more responses with a similar result this time but i shouldnt abuse this site
  12. Delacerda.diegofelipe
    san francisco
    thank you everyone for your responses i highly appreciate it. First thing tomorrow i will check and replace the 12 v. and then take it from there
  13. Delacerda.diegofelipe
    san francisco
    no it had one prior owner. im going to check and replace the 12v as soon as tomorrow
  14. strawbrad
    953
    999
    CALL TOYOTA!
    Ask for the date your car was placed in service, that means the day the original owner purchased the car. If it is after Sept 1, 2005 you could get a free battery under warranty.
    Brad
  15. dolj
    dolj Senior Member
    7,657
    3,868
    A free HV battery under warranty. You still need to replace the 12 V, in any case, on your dime.
  16. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    Some have had decent results using an inexpensive motorcycle or mobility battery. Maybe just as a test, since you may subsequently junk the car. I believe the cost difference may be in how venting is accomplished, a minimal issue in my opinion. Others may wish to correct me. Cranking amps is actually more important on the motorcycle than on this car.
  17. bisco
    49,492
    also, lawn tractor battery. cheap money at lowe's.
