What size is the Transmission fill plug?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SLO Cat Wrangler, Jul 21, 2012.
  1. SLO Cat Wrangler
    SLO Cat Wrangler Junior Member
    96
    San Luis Obispo, CA
    Hello everyone,
    So I got ready to change my ATF in out 2008 Prius and realized that the fill plug has a standard bolt head (not a 10mm allen key head). The drain plug has the 10mm allen key.
    When I went through my tools, I didn't have a socket that would fit (largest I have is 19mm).
    Can someone...
    1)confirm that the FILL plug on a 2008 Prius is NOT a 10mm allen key
    2)Tell me what size socket I need for this (Metric I suspect, but maybe SAE?)
    Thanks
    -Steve
    P.S. if the fill plug is a 10mm allen key then I'll keep looking for the fill plug.
    P.S.S So my measuring calipers say the bolt head is 24.6mm. When I convert this to inches it is 0.965 inches. My 15/16th socket (0.9375) fits, it is a tiny bit lose but expected. Is this what people use or is there a metric socket that is used.
  2. SLO Cat Wrangler
    96
    San Luis Obispo, CA
    One more thing. If the fill plug is NOT a 10mm hex allen head, could it be replaced with one? Do the GenIII have 10mm hex allen heads on both the drain and the fill? Could I just order a fill plug for a gen III prius and swap?
  3. SLO Cat Wrangler
    96
    San Luis Obispo, CA
    OK so for those who want to know here are the answers provided by the one asking the question :)
    I used Clear Vinly Tubing (home depot) with an O.D. of 7/16" and I.D. of 5/16" to attach to a funnel.
    The Fill plug transmission size. 15/16th socket worked to get it off and back on.
    Torqued to ~ 29ftlb. This seems pretty light so don't become the HULK.
    Added 4 qts fluid from Toyota (ATF/WS) , but some drained out (~ 100-200ml)
    -Steve
  4. Patrick Wong
    18,200
    6,479
    The fill plug size is 24 mm, but as you learned, a 15/16" socket works well. It is best to use a six-point socket to avoid potential slipping and damage to the fill plug hex shape.
  5. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
    The correct socket size is 24mm.
  6. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Double check against this picture taken by hobbit to make sure you got the correct plugs. Good luck!
  7. SLO Cat Wrangler
    96
    San Luis Obispo, CA
    Thanks for the pict. Already got the job done and now have new clean ATF WS in my car. Thanks for the picture again.
    Steve
  8. Avi's Advanced Automotive
    775
    360
    This is a great tip, I only use 12pt sockets on 12pt nuts and bolts.
