what size oil filter wrench
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by paul gerber, Jul 14, 2013.
  1. paul gerber
    paul gerber Junior Member
    16
    which size oil filter cap wrench is used on the 2011 filter cap?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    if you search the forum, there's plenty of threads with this question. I hope this helps.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    64 mm. The more standard 65 mm will fit but will slip if filter is overly tightened.
  4. JDB
    JDB Junior Member
    24
  5. Mike500
    Mike500 Senior Member
    2,593
    764
  6. JDB
    JDB Junior Member
    24
    WOW that IS expensive. Any reason you didn't go with TOY640?
  7. Mike500
    2,593
    764
    It's an investment.
    I liked the all steel construction wilt a full weld around the collar and the 3/8 socket drive.
    Also, it is Made in USA by OTC.
  8. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
