What size subwoofer(s) do you use?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Zexesy, Nov 18, 2017.
  1. Zexesy
    Zexesy Junior Member
    Everywhere
    One more question:
    Have you had an issue with your rear view mirror breaking off?
  2. R-P
    R-P Active Member
    808
    288
    Netherlands
    I have had a 12" for a while, and swapped it for a 10" that left some more room for everyday use. Driving it with 200W. Not nearly enough to have the mirror drop off.
    Plans are to go for 1 (vented) or 2 (sealed) in the below idea (the orange part being the baffle, the space below will be the enclosure (so I loose the cargospace there), carpetted so you won't even see it is there and the boot can be used as normal), but then of off 420Wrms (single Aliante LTD, 500Wrms) or 800Wrms (double Aliante 2x350Wrms). But that may not happen until way in 2018... Time is in short supply.
  3. frodoz737
    frodoz737 Top Wrench
    4,721
    2,517
    33
    10" sealed in the back of a Gen III is more than enough if the cone is quality you power it right.
