What size windshield wipers do I need for 2009 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Joe Wall, Jan 3, 2023.
  1. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    I got them for Christimas but the 18" windshield wipers appear too small. I received 18" and 26" wipers. I'm guessing I need 19" ones but just want to confirm.
  2. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,839
    Hyampom
  3. dolj
    dolj Senior Member
    8,553
    4,345
    Wellington, New Zealand
    Mine are:
    Drv Side 26"
    Pass Side 18"
    Rear 16".
    I usually just get the blade inserts which are a universal type that you snap the metal inserts off at the closest score mark and cut the blade length to match so I make mine as long as practical. (Mine are therefore 0.4 and 0.1" (respectively) longer than the above measurements.)
    With getting inserts IIRC there are different blade widths left and right. D - 8 mm; P - 6 mm. Not sure if they are designated in mm or inches in the States, but if I had to guess they probably would be (just under) 3/8" and (just under) 1/2" respectively.
    The exact measurements in mm are D - 671; P - 460; R - 400. (max 406)
    I don't know if that is of any help.
    #3 dolj, Jan 3, 2023
