What sort of unleaded Gas do you use?
Discussion in 'Gen 2 Prius Fuel Economy' started by zmyal, Mar 31, 2005.
  1. zmyal
    zmyal New Member
    Indiana
    I am pretty new, I bought my Prius 2005, few days ago and I was wondering what kind of octane you guys fill in your sweet cars. :roll:
    Please advice
    Thanks :p
    SAM
  2. Tideland Prius
    16,127
  3. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    87 at Citgo mostly. The stuff at Wal-Mart has been OK when price mattered more...
  4. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    87 Only (Or 85 in the Mountains if that's all there is)
    Anything else can lead to check engine lights and other undesirable things.
  5. zmyal
    zmyal New Member
    Indiana
    so I guess I should not go for the most expensive one huh? well that's another plus to this awesome car...
    Prius Rules!
    SAM
  6. 200Volts
    200Volts Member
    429
    43
    Northern CA
    Liquid unleaded gasoline works best.
  7. NuShrike
    NuShrike Active Member
    1,378
    Owner's manual. 87 unleaded.
    Octane is not a measure of how much power the gasoline has, but how resistant it is to combustion.
    Higher resistance (octane) is needed in higher-compression (higher HP) engines to prevent knocking which the Prius engine isn't.
    Of course the Prius engine can probably adjust to higher-octane gas, but wouldn't get more mileage/power so you would be just wasting money, and possibly building up deposits in the engine/exhaust.
  8. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    My Prius currently has a tank of 87 Octane Costco gas in it. Car seems happy enough, so I won't argue with it.
  9. rflagg
    rflagg Member
    947
    Springfield, VA
    Yep, 87 is just fine and dandy for this wonderful car. There have been a few documented cases on here where drivers have tried higher octane fuels for a few tanks to show there was no increase in MPG.
    -m.
  10. popoff
    popoff New Member
    560
    western NC mountains
    Not combustion but detonation or preignition. Big difference! Detonation is uncontrolled combustion which is very harmful to the engine in that the fuel mixture ignites prematurely and in an uncontrolled fashion. This can wreak havoc on the pistons. The audible result of detonation is what used to be called "ping." I believe today's engines have sensors that detect detonation and retard the timing, as required, to protect the engine.
