What the heck IS this?
Discussion in 'Gen 2 Prius Main Forum' started by GuamKelly, Jul 6, 2021.
  1. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Found while going in to remove hybrid battery. Never saw this before, no idea what it is, but it doesn't look good, whatever it is! Markings are
    EMLA 0795100100011
    49,545
    looks like an aftermarket product, missing something
    PriusCamper likes this.
  3. wjtracy
    wjtracy Senior Member
    11,326
    3,593
    Northern VA (NoVA)
    Geez the guy didn't even trim the spare 50-ft of wires. Is it connected to 12v such as inverter ?
  4. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Right? I'm the second owner, have NO idea what the heck the original owner installed here. Looks like when the Stealership diagnosed the battery and ECU it fell out of .... somewhere. Certainly not a Toyota looking job, whatever it is!
  5. DutchPrius
    DutchPrius Member
    78
    46
    Leiderdorp NL
    Are you able to follow the wires to another connection or source? Tine wires, appears to me that it's audio or video related like for the rear cam or so. Does that still work?
    Best regards, Nick
    Black 2007 Prius
  6. Frontporch
    Frontporch Member
    398
    82
    Nj
    by the look of it, I wonder if it does anything anymore. I would be tempted to check it if still has power with a test light.
    Being in the trunk it is suspicious that it might be something for a trailer setup, audio or backup camera related.
    There is a lot of corrosion. If that was sitting in the spare tire well, looks like you might have some water issues like I did. I had lots of water in the spare tire after a good soaking rain. Was the roof seals by the hatch that cracked. Easy fix if you are interested.
  7. ski.dive
    ski.dive Active Member
    897
    232
    Hutchinson Island,FL. Mt. Snow,VT
    I see RUST under the spare tire....
  8. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Looks like a speaker grill on it
  9. privilege
    privilege Active Member
    659
    169
    Birmingham
    looks like it's a backup beeper
  10. DutchPrius
    DutchPrius Member
    78
    46
    Leiderdorp NL
    Yes that's my guess as well...
    Best regards, Nick
    Black 2007 Prius
  11. bisco
    49,545
    maybe a moisture detector for the tire well
  12. ChapmanF
    15,731
    I'd say it worked.
    Mr. F likes this.
  13. nssdiver
    nssdiver Me digging' life
    Syracuse, NY
    Four Touring
    My money goes on an aftermarket electronic rust inhibitor.
    Look for another similar unit at the end of the second wire.
    iPhone ?
  14. ChapmanF
    15,731
    Ok, I'd say i didn't work.
  15. Another
    1,802
    511
    Naples, Florida
    Bug zapper?
  16. ChapmanF
    15,731
    Can't tell if it worked.
  17. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    If it was a rust inhibitor, it didn't. The corrosion on the floor of the trunk is due to a bad hatch seal (since replaced).
    It's hooked into the rear lights -- I'm thinking someone tried to add a backup beeper or camera, but there's no other evidence of either that I can find so far. I'm just going to take it all out.
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Battery hole is probably really rusted out in the bottom. Seen a few on here so bad the battery can fall out of the car.
  19. ETC(SS)
    6,569
    If you've lived in Guam for any length of time at all, then you already know about corrosion prevention, AND tropical downpours so I won't go into that.
    Your car might have been a former fleet or company vehicle (like mine) with some non-OEM "safety" gear - like a backup beeper.
    Delete it and get on with your life!
    The first time I made it to Guam was aboard a NOAA ship, and we all had access to the CPO club.
    They would have let me in anyway ;)
    Somebody "forgot" to tell the scientists and deck crew what happens when you walk into a USN club "covered" (wearing a hat.)
    I didn't buy a drink all night! :D
    Good Luck!
    #19 ETC(SS), Jul 16, 2021
