What the heck is wrong with my Prius??
Discussion in 'Gen 2 Prius Main Forum' started by macmaster05, Feb 20, 2013.
  1. macmaster05
    macmaster05 Senor Member
    4,050
    729
    For the past week, 80% of the time I turn on my car, my overhead light flickers and I get a warning light with the red triangle and "!" Today, when I got in from my car after work, there was a constant interior beep (with car off) and when I pressed Power, I heard a single honk + the red triangle (!). The final symptom is that if the overhead light is on, and the water coolant sound goes off, the light dims about 50% and flickers (FYI, I switched the overhead lights to LED a couple years ago).
    I think this all started when I left my interior light on maybe 2 weeks ago. But since then I haven't left my lights on, and as I said, the problem is intermmitent. I've referred to the Prius manual as to what the red triangle (!) means and all it said is this (page 427): Master Warning light: A buzzer sounds and the warning light comes on and flashes to indicate that the master warning system has detected a malfunction. .... Take appropriate action in accordance with the message displayed on the touch screen. The problem is I don't see a message on my screen. Plus this is only a problem that is symptomatic when I turn my car on or off, and interior lights are on/off. There's nothing wrong with the driving or mileage, as far as I can tell.
    What is wrong with my Prius? I'm worried one day it's not going to turn on... Thanks.
    49,389
    bad 12 volt?
    macmaster05 likes this.
  3. bobodaclown
    bobodaclown Member
    214
    71
    Check the 12 volt battery.
  4. macmaster05
    4,050
    729
    How do I check? Is this free at a dealership?
    Edit: working on it..........
  5. bisco
    49,389
    there is a self diagnostic that can be performed on the mfd. i don't have the link but it's here somewhere. someone will post it if you can't find it. i think the thread title is something like 'funny things happening? check the 12 volt'.
  6. bisco
    49,389
    is anything free at the dealership? you can ask i suppose.
  7. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Here's the link
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
  8. macmaster05
    4,050
    729
    Thanks for the link I checked the 12V and I'm just as confused as before:
    Vehicle Signal Check: was at 9.8 (12.4-12.8 is normal). Not looking good.
    Pressed power to put a load on the battery: dropped to 9.4. Again, not looking good.
    Braked, turned car completely on: Went up to 14.0. Isn't that normal?
    So do I have a bad battery, or not? Does it absolutely need to be replaced? If it does, how much longer do I have until my car won't turn on? I feel like the 12V battery will recover over time, like a person's immune system, or a hybrid battery that gets recharged, haha. But unfortunately that's probably not how it works. I'm not sure what to make of those results...
  9. bobodaclown
    bobodaclown Member
    214
    71
    Yes you're due for a new battery! There are plenty of messages.
  10. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    I wouldn't say "bad" because it's not as though it's defective. Just aged and not holding a solid charge anymore.
    No, but like my Dentist says, "you don't have to brush all your teeth; only the ones you plan on keeping."
    Haha. Dream on... :)
    Seriously though, it should be soon. Real soon.
  11. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    the yellow top Optima - eLearnAid.com - can be shipped fairly quick I think.
    Supposed to be a little more hardy to discharges.
    If colder the 12v has less power so maybe that explains the intermittent (sp?).
    Chilly here 24F now.
  12. macmaster05
    4,050
    729
    Before I plop down $200, is this true??
    If the 12V battery is low you can try using the Prius itself to recharge it by turning the car fully ON ("Ready", as though you were going to drive it) and letting it sit with the shift in "Park" for nine hours. It can take that long for a full charge because the battery is rated at 36 Amp-hours, and the system is limited to 4A. Of course be certain that the car is physically secure, and, if indoors, has an adequate air supply.
    Also, is the one sold on eLearnAid the one that doesn't require the converter kit?
    I also found this on Amazon, is it the same one (that is a direct replacement/no kit needed)?
    Optima Batteries 8171-767 Yellow Grp S46b24r 450cca : Amazon.com : Automotive
    Basically, where do you recommend I purchase from?
    Also, for purchasing and informational purposes, I live in Los Angeles. It's 54 degrees now.
  13. macmaster05
    4,050
    729
    And you guys are absolutely sure that these warning lights are due to a low 12V battery? I'm only at 52,000 miles.
  14. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Your 12 volt is toast or at least its voltage is WAY low. You could try putting it on a charger and charge at no higher than 4 amps to see if it holds. An alternative to buying a charger is leaving the car in READY mode for 8 (!) hours (Stall-out/Recall | PriusChat). Prius DC to DC converter charges the batttery real slow. :/ Doesn't matter if you drive the car or not during those 8 hours. It won't change the charging rate.
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + & Plug-in Prius with Instructions doesn't require a conversion kit. I bought Toyota Prius 12 Volt Auxiliary Battery with install kit for 2004 + including Plug in before the direct fit version existed. I bought from them.
    They're down in So Cal. Some folks have gone there to pick one up.
  15. macmaster05
    4,050
    729
    Thanks Andrew. I'm gonna call them tomorrow to see if I could pick it up.
  16. macmaster05
    4,050
    729
    Wait - I'm confused with what this achieves. Are you saying if I leave my car on overnight (8 hrs), then my battery unloaded will be back at 12V, no more warning lights, no need to buy a new battery, and problem solved??
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    He's pulling everyone's pudding. 4 years and 4,000 posts.
    At least I sure hope he is.
  18. macmaster05
    4,050
    729
    Hah. Nope. I haven't learned nothin'. Most of those posts were about mods or like "hey I like your mod."
  19. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Maybe. The car will attempt to charge it, but the voltage still might be low. Or, it might end up being low again after a few days. If that's the case, you'll need to replace the 12 volt.
    If you've been doing pretty long drives every day or most days and don't have anything causing a drain (e.g. leaving a light on, some device draining the batt, etc.), then it's safe to assume the 12 volt is just toast.
  20. macmaster05
    4,050
    729
    It sounds crazy. And you're SURE it won't ruin my car tomorrow morning? I gotta go to school.
