-What Tire PSI is your Prius running?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 21, 2021.
  1. ski.dive
    ski.dive Active Member
    967
    245
    Hutchinson Island,FL. Mt. Snow,VT
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I get the longest tire life at 40 PSI Front 38 PSI Rear.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    ~38psi all around.
  4. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I run 42 PSI front and 40 PSI rear in my Prius tires which are rated as 51 PSI Max cold.
    JeffD
  5. PriusCamper
    PriusCamper Senior Member
    13,069
    5,306
    Pacific Northwest, USA
    Ecopias ---> 47psi in front & 45psi in rear
  6. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    My Volt and 1999 Insight stay between 50-60psi in the summer
    Much better tire life
    PriusCamper likes this.
  7. ski.dive
    967
    245
    Why so High tire pressure for such a Light weight car???
    Wont it make it harder to stop the car with such high tire pressure? ?
  8. bisco
    52,393
    i run 20 at each corner. the traction, braking and handling are amazing, and it is your fathers oldsmobile.;)
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    ONLY until one of them explodes because of chronic over-inflation.
    Stupid is the only word that comes to mind.
  10. Rmay635703
    2,669
    1,694
    2013 Chevy Volt
    Got 80,000 out of the OEMs that came on the car, helps when the sidewall is rated over 50psi
  11. Tideland Prius
    16,621
    When we had the Gen 2, we ran 40/38 both on the original Goodyear Integrity and Nokian WR.
    Gen 3: 38/36
    Gen 4: 33/32 (factory setting)
    Prime: 40/39
  12. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    35 PSI Front
    33 PSI Rear
    I have tried higher pressures up to 44/42 and found no significant improvement in MPG over a couple of tire cycles. Tires had to be scrapped early due to the centers wearing out before the sides. So went back to the Toyota recommended pressures above. Tires last much longer. Traction and braking are good, too.
  13. fuzzy1
    10,603
    If so, then Wayne Gerdes and his cadre must have considerable experience with these explosions.
  14. The Lizard King
    89
    56
    36 psi all the way around.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Explain please.......or not.
    Somehow I think it will not be useful information.
