What to do with the blank fog light “rubber circles†on the 2010 Prius II/III/IV
Discussion in 'Gen 3 Prius Accessories and Modifications' started by jlynnwatts, Dec 10, 2009.
  1. jlynnwatts
    jlynnwatts New Member
    17
    [Opinion: I have never liked blanks on instrument panels where there would otherwise be optional buttons. I do not like the rubber “blanks” on the front bumper in place of the fog lights. I do not “need” the fog lights. However, I do not like the rubber circles in place of the fog lights.] (Quote from a closed thread by "Prius in Paradise")
    I agree. I have fog lights on my RAV4 and rarely use them. The blank circles on the front of the Prius II/III make the front seem somehow unfinished. I decided to look for a 2” white reflectors with double sided tape that I could slap on the plastic circle. I couldn’t find anything that would fit or look good.
    While I was looking for the reflectors, I stumbled on some convex “Blind Spot Mirrors” by “Custom Accessories” in a True Value Hardware store(also on Amazon.) They come in a 2-Pack with tape on the back for less than $4. I added some extra double sided tape and placed them on the “rubber circle” on the front of my Prius. They actually have an angled face that helps to compensate for the angle of the blank “rubber circle”. I think they help to clean up the blank “rubber circle”. Of course installed fog lights would be the best solution, but they seem so pricey. (see pics)
    At first I was concerned about causing a reflection from oncoming traffic that might be a safety concern, but I think any chrome might cause a similar reflection. It might be a good idea to buy an extra pack just in case they get broken or fall off.
    UPDATE: Walmart carries the same "Blind Spot Mirrors" for less than $2
    What do you think?
    Any other ideas?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    A mirror on the front of the car is probably illegal in some states.
  4. austingreen
    austingreen Senior Member
    13,566
    4,101
    Austin, TX, USA
    I'll add the real fog lights. Toyota should have had them as an option. I want to decide whether to get a stalk, and install daytime running lights too, or use a switch on the panel.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Keep in mind because you have a II, you won't realize the full potential of the stalk (e.g. you won't have the foglight emblem light up in the console). So for the trouble and cost you are only getting a real fancy switch. I just went with the switch in the panel.
  6. Strangelove
    Strangelove New Member
    Washington, Pa
    Can fog lights, or driving lights, be wired on a II so that they come on automatically with the headlights?
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes. That is the way I have it wired (per the document). I installed the switch that came with the Yaris harness so that I could turn off the fog lights whenever I needed to despite the headlights/parking lights being on.
  8. jlynnwatts
    17
    I believe a convex mirror is sometimes referred to as a diverging mirror due to the fact that light originating from the same point will reflect off the mirror surface and diverge. In other words a convex mirror will spread the reflection not concentrate it. (see diagram)
  9. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    Just get the blue ones, very cool stuff!
  10. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    If you arent going to put in fog lights, I think a pair of fully automatic weapons or rocket launchers would make a great addition for those slots. Maybe the next James Bond movie will feature a Prius with such amenities.
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    there should be room to install a couple paint guns
  12. DavidA
    2,328
    1,812
    Chicago western burbs
    Since lasers, rockets, guns, mirrors are no doubt illegal to install, maybe a trip to a novelty store is in order. A pair of rubber hands, feet, or rubber chicken heads sticking out of those sockets could be an attention getter.
  13. patsparks
    10,664
    567
    Adelaide South Australia
    I like the mirrors.
  14. Tideland Prius
    16,125
    Not a bad idea. I'm wondering if anyone can come up with some LED stuff for the foglight blanks. Perhaps have an L-shaped design for those who want DRLs (kinda like the new E-Class). Or maybe 3 columns of single-row LEDs to get a vertical light look like one of the Prius concepts.
  15. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    cheapest fog lights...
    1. take picture of real Prius fog lights
    2. print out to scale.
    3. cut them out.
    4. mount on plastic below lights
  16. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Has anyone tried to paint the inserts?
  17. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  18. DavidA
    2,328
    1,812
    Speakers?
  19. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Air horns!
  20. Presario
    Presario New Member
    Los Angeles
    How about missile launchers?
    I like the idea of something going over the empty covers, but the mirror seems like it could be potentially hazardous. Looks good though.
