What to look for in a test-drive of used 2013 Prius
Discussion in 'Gen 3 Prius Main Forum' started by John Fish Kurmann, Jul 11, 2021.
  1. John Fish Kurmann
    John Fish Kurmann Junior Member
    31
    Kansas City, Missouri
    So my 2002 Prius was taken out on 6/18 by a red light-runner (fortunately I was not). I'm not in a position to buy new even if there was much supply so I've been patiently looking for a used 3rd-Gen Prius that wasn't overpriced by 20-30% due to current market conditions. I finally found this one near me with 101,188 miles on it: Used 2013 Toyota Prius Prius II for Sale in Blue Springs MO 64015 Toyo Motors
    Based on the Carfax it seems to have been well-maintained but I'm concerned about potential problems with the head gasket based on what I've read about the 3rd-gen. What should I look and listen for regarding that issue? Any other suggestions when I test-drive it on Monday?
  2. Mendel Leisk
    40,586
    More’n likely the Exhaust Gas Recirculation is neglected, but the miles are not so high as to be too late. You would want to get on it soon. Isn’t it nice, picking up a relatively low miles recent car, knowing some fairly involved wrenching is near-immediately needed…
    more info:
    Bad Flywheel | PriusChat
    Tim Jones likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,894
    Texas Hill Country
    A start up rattle that sounds like a rod is broken is a hg. However most fail slowly at first sometimes going months between rattles. Any sign of dark or low coolant, turn and run. The reality is a can of sealant and a coolant change can hide a hg issue. These sometimes result in replacement engines and Toyota has no program help. Businesses specializing in hg replacements have resulted. Its a serious concern.
    Excessive oil consumption is common 2010-2014 and clearly increases blowby, egr clogging and intake manifold oil collection via the hard to access pcv. Caused by a flawed design piston and ring assembly. Bad enough that Toyota would replace pistons and rings during the powertrain warranty. However most issues show in the 150k mile range.
    Inverter and Brake Booster design flaws also are chronic, especially the brake booster. Customer Support Programs will fix a failed unit for at least a year on a 2013 with your mileage. The weak booster will run excessively, as often as every 20 seconds if leaking. However it will not throw codes and qualify for the free replacement until it takes minutes to satisfy. A difficult diy.
  4. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    No.............
  5. bisco
    51,155
    at least 2016, if you want almost 20 years like your 02. go big or go home...
  6. John Fish Kurmann
    31
    A 4th-Gen won't fit into our budget without a load of miles on it, unfortunately. Also, my 2002 needed a new traction battery and transaxle at the time I bought it with ~133,000 miles on it. The dealer reduced the price and I paid for the battery replacement, Toyota replaced the transaxle at no cost to me after that problem was discovered.
    #6 John Fish Kurmann, Jul 11, 2021
  7. bisco
    51,155
    well, it certainly sounds like you'll be able to handle all of the gen3 problems!
  8. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Put a clean rag under the driver's seat and rub the seat springs.
    Automakers use cheap steel for those springs, so if the car ever got flooded the rag will come back rusty.
  9. John Fish Kurmann
    31
    Just as an update, we inspected this Prius today and, while much of it looked good, there were two red flags and I decided to not even test-drive it. There were chunks of asphalt dried inside the wheel wells and a black, semi-oily residue at the end of the tailpipe, which is one of the things Consumer Reports recommended checking. They say the residue should be dry and grey in color.
  10. Mendel Leisk
    40,586
    Ours is dark grey, but by no means oily.
  11. ASRDogman
    ASRDogman Senior Member
    7,243
    3,781
    Consumer Reports? ha ha ha ha ha That's funny!
    All my cars have dried asphalt in the wheel well. It gets there from repaving roads.
    And my tailpipes are wet all the time, because of the catilitic converter.
    Eventually they try if they sit for a few hours or so, the moisture evaporates.
    Those are not very good reason for not buying the car.
    You have to take what cr says with a grain of salt. Manufacturers PAY them to say certain things....
    Grit likes this.
  12. John Fish Kurmann
    31
    There was quite a lot of asphalt in the wheel wheels, including at least one very large chunk. This was far from an ordinary amount.
    The residue in the tailpipe was black and partly oily. It should not be.
    Where is your evidence that "Manufacturers PAY [CR] to say certain things"? I'm sure they would vociferously dispute that.
  13. John Fish Kurmann
    31
    It wasn't dark grey, it was black as night.
  14. Mendel Leisk
    40,586
    I’d concur with that. I do think their credibility is slipping though. Or maybe it’s people realizing they are “spread pretty thin”, ie: their product assessments are not that thorough.
  15. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    let me see put the current political tactic on that, where is your proof and evidence that manufactures are NOT paying cr to say certain things?
    list sources also.
    ASRDogman likes this.
  16. John Fish Kurmann
    31
    No, you're making the accusation that contradicts what CR asserts about their independence. Therefore, the burden of proof is on you.
    This is what the tailpipe smudge on our 2004 Prius with about 239,000 miles on it looks like, and what CR says it should look like. This is not at all what the smudge on the 2013 Prius I've been talking about looked like.
  17. John Fish Kurmann
    31
    I don't buy lots of stuff for which CR posts reviews, but I've never discovered any problems with the products I've bought for which I did rely on CR reviews. Everyone's mileage varies, of course.
  18. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    ha, I was using the main stream media type of argument tactic to stir a response. People think the media is right & credible for that method of questioning.
  19. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    thanks for the helpful tip. If I ever should sell mine, I’ll give the tailpipe a very thorough cleaning just in case.
    Samuel Williams Jr and ASRDogman like this.
  20. John Fish Kurmann
    31
    Surely you're not admitting you would sell a car you knew had a major engine problem and cover up the evidence. That would be a really lousy thing to do to someone.
