What to look out for in 2004 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Infamous6i9, Feb 9, 2019.
  1. Infamous6i9
    Infamous6i9 Junior Member
    61
    Los Angeles
    My coworker is selling me her 2004 gen 2 prius with 200k miles because she rarely uses it. What things should I look out for when purchasing the 2nd gen Prius?? I've owned a 3rd gen and currently have a 4th gen prius, so I dont have much experience with the 2nd gen. All I know is she replaced the batteries and got a new catalytic since people stole her stock one before.
    49,576
    2004's are tanks. that said, it's important that the hybrid battery is new, oem, not reconditioned or rebuilt.
    of course, any car that age can have substantial 4 figure repairs needed at any time, that you cannot detect now. as well as normal things like shocks, struts and etc.
    reset the trip meter and take it for a good long ride under varied conditions. listen for odd sounds, and check to see what she returns for mpg's.
    do they have the complete maintenance history? any accidents?
    how will you know if it's an oil burner?
  3. JC91006
    16,488
    8,402
    If you plan on parking this car on the streets of Los Angeles, the catalytic converter will probably get stolen again. So if you don't have a garage space, you should just pass
  4. kens97uber171
    kens97uber171 Active Member
    177
    132
    US
    One of the common fails on the second gen Prius is the brake accumulator pump. some of them never fail others do. You buy remanufactured ones now for about $600.
    I would take it for a decent test drive reset the trip and MPG and see what it gives you. Always a possibility that's an oil burner but that's true with any car, and quite frankly oils cheap. the risk of having the catalytic converter stolen again I guess is true but that's the same on any other car also. perhaps more so because there's not much room under the Prius they would definitely have to jack it up to get under there.
    I personally like the interior on the second gen a bit more even in the third gen. I think the material quality they used was a little bit better. You don't get quite as much information as you do on a 3rd gen as far as efficient driving. It doesn't have the little meter that goes from braking to eco the power..
    however there are apps you can get on your phone to connect to an OBD2 Bluetooth connector. And you can get some of that information that way if you choose. If you have one of those devices already you can use dr Prius app to do some battery testing. The one I use on a daily basis is called hybrid assistant, it can help you drive more efficiently mostly it can help you brak more efficiently. It also gives you some temperature readouts on engine, inverter, mg2, battery, and it will allow you to override the cooling fan speed profile. I live in a hot climate during the summer. And I have it set to override and go to the maximum cooling at 115 degrees Fahrenheit. Keeping the battery cooler can extend its life.
    If the car runs and drives well, and she's not asking that much for it I don't really see what you could lose. But I don't think I would pay more than $5,000 for it. $3k would be better.
  5. bisco
    49,576
    coincidentally, someone else just posted that they are looking at a 2004 with 200k, with a dead 12v.(n)
  6. LikeAPrius
    LikeAPrius Member
    100
    26
    2019 Prius
    I wouldnt pay more than 1500 for it to be honest
