What to look out for in buying used for daughter?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Laura Drew, Mar 20, 2019.
  1. Laura Drew
    Laura Drew Junior Member
    Jackson WY
    We are just starting our search for a Prius for our daughter who is graduating from college in Portland OR.
    Our $$ budget is $10k and we saw a 2013 in Salt Lake City at a dealership which we might have been able to talk them down to 10K. I have looked online and it seems there are not too many options near us (Parents live in Jackson WY) so looking for suggestions on where to look and what to look out for.
    The things my husband specifically asked about is:
    Timing Chain
    Battery
    and any other things that are known to start going kerflooey!
    I know that may be a long list. I did read some old threads one specifically about timing chains NOT needing replacing.
    Thank you for any and all advice. My daughter was driving a manual 98 subaru outback until it was stolen- apparently it is the #3 car stolen in Portland. So any info on that nugget would be appreciated as well. thanks:)
  2. Tideland Prius
    16,145
    The Gen 3 (2010-2015) have a beltless engine so the water pump, A/C and other accessories are electrically driven. This means there’s no timing belt or chain.
    There are two batteries - your standard 12V car battery and the hybrid battery (sometimes known as the HV battery, or traction battery). You’ll want to check both. The hybrid battery will have to be checked by a Toyota hybrid technician so I would take it to a Toyota dealer (if the car in SLC isn’t at a Toyota dealer) to have it inspected.
    Just ensure that the recalls are up to date and that the engine runs fine in idle (no weird noise from the engine itself). When you’re test driving it, ensure the hybrid battery can hold a charge (it’s programmed to stay at the 80% mark on the dashboard display. It won’t go full unless you go down a steep hill so don’t worry if you never seen full). It’s more worrying if it stays near 10-20% on the battery meter display (which indicates that it can’t hold a charge).
    49,435
    Depends on the mileage and how many miles she wants to keep it for.
    Once you get near 100k, a lot of expensive repairs are possible unless you diy.
    Try finding a hybrid mechanic outside a dealer$$$$$$$
    Maybe a Corolla or something else simple?
  4. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    Huh? There is a timing chain. It doesn't seem to be high on the list of troublesome parts on this car, thankfully.
    SFO and Leadfoot J. McCoalroller like this.
  5. Tideland Prius
    16,145
    I thought the Gen 3 Prius’ engine was beltless. - that was one of the points Toyota brought up at the launch presentation.
  6. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Find the lowest mileage one that you can. These cars have some very expensive issues (in addition to the battery) once they approach the 150K range.
    If $10K is your budget, there may be other cars that are a better fit.
    The engine does not have drive belts for the accessories. But the camshafts and the crank have to rotate in sync - which is what the timing chain does.
  7. orenji
    orenji Senior Member
    5,884
    3,486
    Not sure about this information? Gen 3 has no timing belt, it has a timing chain, that should never wear out.
    Gen 3 can go 200k plus miles with very little issues. Gen 2 and Gen 3 are some of the most reliable cars on the road.
    Gen 3 can burn oil, it important that oil is changed at 5K miles not 10k miles. Check oil every fill up. Use thicker oil then 0W-20. I currently use 0W-40.
    Change trans fluid every 60k miles. If the car has 100k miles to 130k miles make sure EGR is cleaned out. If the car has more miles and EGR has yet to be cleaned I would pass. May have head gasket issue down the road.
    Lightning Racer likes this.
  8. The Critic
    3,193
    2,321
    CA
    The headgasket issue is kind of a wildcard. Cleaning the EGR may help but I'm doubtful. Mine was cleaned and the cooler was not blocked. Yet my headgasket still blew. I would say that if you plan to keep the car past 150K, be prepared to replace both the headgasket and the battery at some point.
    Tim Jones and Raytheeagle like this.
  9. orenji
    5,884
    3,486
    How many miles when you cleaned the EGR?
  10. The Critic
    3,193
    2,321
    CA
    I cleaned the valve and tube at about 160k (I think), and then cleaned the EGR cooler at 179k. The headgasket blew at 185K.
    The valve and the tube had a light amount of buildup. The cooler had some buildup, but it still flowed fine.
    Raytheeagle likes this.
  11. Tideland Prius
    16,145
    Thanks for that!
  12. orenji
    5,884
    3,486
    Sorry you had your head gasket blow. But I think you waited too long to have your EGR system cleaned. I think 100k miles is best to clean your EGR.
    mjoo likes this.
  13. The Critic
    3,193
    2,321
    CA
    But if the cooler was not blocked, what advantage would have been gained by cleaning at 100K?
    mikey_t likes this.
  14. orenji
    5,884
    3,486
    I am certain the cooler was 99% blocked at 100k miles.
  15. The Critic
    3,193
    2,321
    CA
    Every cooler is going to load up at different rates. It really depends on the driving conditions.
    mikey_t and Raytheeagle like this.
  16. orenji
    5,884
    3,486
    Well the ones that have been done at 100k miles or so have been clogged up.
  17. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    All the ones I have done (the number is 10) have all been at varying degrees of pluggage;).
    No two are the same and no two are in similar situations :cool:.
    Don’t forget 8 of these 10 are for Prii in a generally calm, sedate and easy on the car condition. And I’ve not had one plugged solid ;).
    But they are out there(y).
    SFO likes this.
  18. orenji
    5,884
    3,486
    Calm, sedate and easy on the car condition? I assume you are speaking of the drivers? Any EGR that is not free and clear is causing restriction and higher temps. I just had mine done. 105k miles. I am very easy on my car. There was a pin hole of light that could be seem through the cooler.
    Tim Jones likes this.
  19. The Critic
    3,193
    2,321
    CA
    I wonder if that is part of the problem. Mine is driven hard - I have a heavy foot. I average 40-42 mpg (on 17" wheels), 30k out of a set of tires and 90-100k out of a set of front pads. Cars that are driven tend to have less carbon buildup.
    SFO likes this.
  20. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    By that I meant California. The closest one to completely clogged I had was from @SacLexToy who lives in the Sierra Foothills and does elevation changes frequently as well as deals with wider temperature swings. California is relatively flat for the populated areas (I know there are extreme mountains and I’ve taken our 2010 to Tahoe and over the grapevine annually) and moderate climate compared to the rest of the country, and there maybe something to the environment with which you live having an effect on what the engine and related components see and ultimately experience.
    The other 2 coolers were from New York or the New England area where cold and more hilly terrain exists. One of the coolers was only at 94k when I cleaned it and it was comparable to the coolers I see from here around 130k miles.
    Sorry for not being more clear(y).
    SFO likes this.
