What type of 12v battery would be in a 2007...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scott3294, Mar 6, 2011.
  1. scott3294
    scott3294 New Member
    30
    Atlanta Georgia
    AGM, Gel, or Wet.
    Thanks!!
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    36 amp-hour AGM. Is yours going bad?
  3. scott3294
    30
    Atlanta Georgia
    Yep...very weak!
  4. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    Unfortunately, replacement options are limited. Definitely try putting it on a charger first, at 4 amps or less. If that fails to bring it back to 12.4V after sitting overnight, then the two popular replacement options are another one from the dealer or an Optima Yellowtop deep cycle. I did the Optima conversion using the elearnaid.com kit and am very happy with it. Lots of stories and opinions here if you search.
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    You want a AGM battery with a vent, as the battery is in the passenger compartment with you. You do not want battery acid or fumes/gases loose around you or your loved ones.
    The fitment is odd because of the JIS battery posts, but the elearnaid kit handles that.
    http://www.elearnaid.com/12vo1topraub.html
