What type of 12v Battery?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Resilient, Dec 16, 2024.
Tags:
  1. Resilient
    Resilient New Member
    Richmond, BC
    2024 Prius
    Limited AWD-e
    Hi Priuschat,
    I have a 2024 Prius HEV Limited and I am wondering what type of 12v battery is in the trunk of the vehicle. It looks to be a Panasonic 345LN1-MF. Is this an AGM type battery or regular wet battery?
    I have a battery maintainer for the winter period and it has a setting for regular 12v and AGM 12v. Just double checking before I mess something up.
    Thank you all!
  2. Hammersmith
    Hammersmith Senior Member
    1,874
    1,870
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Standard lead acid. It's not an AGM.
  3. Resilient
    Richmond, BC
    2024 Prius
    Limited AWD-e
    Got it! Thank you so much
  4. RandyPete
    RandyPete Active Member
    368
    150
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    You might take a pic of the top of the battery in place and post it.
  5. Mendel Leisk
    40,230
    Any automotive 12 volt charger will charge either flooded or AGM style. It's just some chargers have a setting optimized for AGM, slightly higher voltage I think. Check your owners manual too, for amperage limit, probably 5 amp still (per 4th gen).
    My CTEK 4.3 for example: in the manual it says to use the "snowflake" setting, for charging in extremely cold conditions, or with "spiral-wound" AGM's (the ones that look like a 6-pack). All other AGM's and regular flooded, just use the regular setting.
