What type of oil needed for 2010 Prius with 140k miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by GreenTea&SaltWater, May 14, 2020.
  1. GreenTea&SaltWater
    199
    58
    Los angeles
    Need to know what oil is best for my Prius.
    grantb3 likes this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Conventional 5w30 replace every 4K miles
  3. GreenTea&SaltWater
    199
    58
    Los angeles
    Thanks
    Would Synthetic 5w30 oil be fine?
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Id definitely go with synthetic! Heck you can get a 5qt jug of synthetic for $16 at Walmart!
    Pluggo and GreenTea&SaltWater like this.
  5. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Synthetic
    GreenTea&SaltWater likes this.
  6. Mendel Leisk
    41,170
    What's your oil consumption like, none, modest, moderate, a lot?
    If you're question's mainly what brand, they're all fine, meet the spec. I've used nothing but Toyota oil, fine so far, fwiw.
  7. JC91006
    16,748
    8,554
    You can get 2 (5 quart) jugs of full synthetic 5w-30 at Costco for $24.99. That's what I use on my Prius cars.
  8. Mendel Leisk
    41,170
    Just editorial... :whistle:
    GreenTea&SaltWater and JC91006 like this.
  9. JC91006
    16,748
    8,554
    wanted to stress the Costco workers with longer lines
  10. tankyuong
    1,555
    661
    Central MO
    I’ve used both and both come out dark at 4K miles
  11. burebista
    burebista Active Member
    186
    127
    Romania
    Why 5W-30 and not recommended 0W-20?
    Just curious. :)
    I have the car for 2 years and made 2 oil changes. One with Yacco HY 0W20 and one with Toyota 0W20.
    Any reason to use 5W30?
    Thanks.
    #11 burebista, May 15, 2020
    grantb3 and GreenTea&SaltWater like this.
  12. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    IF there is no evidence of any oil related problems.....keep doing what you have been doing.
    If the vehicle is new to you, use what the owners manual recommends.
    IF.....there are signs of excessive oil usage or other oil problems, then the answer would be somewhat different.
    In general, there really is NO "best" oil. All the majors are more than adequate.
    Mendel Leisk and ASRDogman like this.
  13. sam spade 2
    7,035
    2,801
    2017 Prius c
    Color alone tells you NOTHING about the quality or performance of motor oil.
  14. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    The kind that meets the requirements specified in the OM that you will both monitor and change frequently.
  15. ETC(SS)
    7,106
    Topped-off oil.
    Other than that there won't be $0.05 worth of diff between $2 5w30 that you get at the Dolla store(**) and the $20 a quart super-purple-amsoil designer blend.
    You have a G3 with 140,000 miles on the clock.
    BELIEVE ME
    The flavor of oil that you use isn't going to matter right now.
    You ONLY have to make sure that the oil you use has the API "starburst" symbol on the bottle and is somewhere close to the VISCOSITY that's appropriate for your car:
    (Hint: If you open your hood and find the oil filler cap....it's "probably" printed right there on the cap! ;) )
    (**) I mentioned the Dolla store because they DID sell oil in their automotive section that did not have the API starburst symbol on it.....and people bought it because.....it was cheap.
    Dollar General Obsolete Motor Oil Class Action Lawsuit Certified | Top Class Actions
    Ed Beaty likes this.
  16. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    Not to the original question, but if you haven't yet cleaned your EGR system at 140k miles, the type of oil you use is the least of your worries.
  17. Mendel Leisk
    41,170
    I'm also a bit off-topic, but anyway: I've been putting in precisely the spec'd 4.2 liters (or 4.4 qts IIRC), with oil filter change, and the level ends up a good 1/4" below the top mark. I leave it thus, and there it stays, for the duration, which is good.
    #17 Mendel Leisk, May 15, 2020
    pjksr02 likes this.
