What type of oil should I use on gen3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 2011priusgoofball, Sep 25, 2019.
Tags:
  1. 2011priusgoofball
    2011priusgoofball New Member
    Phoenix
    Hello everyone
    First time posting but been reading these forums for awhile and they have been a lot of help.
    I was talking to someone the other day about the type of oil used in cars. Making me thinking of changing the type I’m using in my 2011 Prius.
    Toyota says to use ow20 but should I use something else?
    Thanks for all the help
  2. StarCaller
    StarCaller Senior Member
    1,244
    697
    Cedar Crest, NM, USA
    2011, phoenix, I'd use some xw-40 oil /
  3. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    i used 5w-20
  4. xerox6135
    xerox6135 Member
    170
    93
    michigan
    themzlab and 2011priusgoofball like this.
  5. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    The user manual clearly says 0W-20. I don’t see a reason to overrule it.
    0W-30 is not much worse though.
    2011priusgoofball likes this.
  6. StarCaller
    1,244
    697
    guess you've never been in phoenix in the summer.... / ;)
    2011priusgoofball and Grit like this.
  7. Attila Fekete
    164
    59
    Budapest, Hungary
    Do you have something different for Phoenix in the manual? Although I’m not a professional of lubes, but 0W-20 do good cooling for the engine due to low viscosity.
    By the way, have you seen the coolant above 80C / 176 Farenheit?
  8. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    The engine coolant on our 2012 Prius hatchback usually settles at 195+/-2 degrees Fahrenheit in level driving at 60-70 mph, although on long climbs up mountains it gets to 200 degrees Fahrenheit. (I believe there is an overheating cutoff somewhere at or above 205 degrees Fahrenheit.)
    I understand that the oil passages on the Prius engine are designed for the thin 0w-20 oil and have been sized smaller than oil passages in older automobiles. Effective oil viscosity thins with increased heat, so to use a slightly higher viscosity oil in higher ambient temperatures is part of the owner’s manual for cars that I have owned. However, I personally would be particularly careful of using a higher-viscosity oil than 0w-20 in lower-than-standard ambient temperatures due to the possibility of insufficient oil flow to the engine bearings.
  9. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    How would you carefully use a higher viscis oil? Not that this is a smirky question.
  10. Robert Holt
    1,313
    888
    If ambient temps were uniformly 80+ degrees Fahrenheit and I observed ICE coolant temps hovering more at 199-204 degrees Fahrenheit, I would consider a 0w30 or 0w40 oil to achieve the same effective viscosity, flow through the oil passages, and oil pressure at the bearings that the ICE would have at a standard 60-degree ambient day with 0w20 weight oil. Frankly, I would simply like an analog oil pressure gauge with green, yellow and red arcs marked appropriately that I could watch during operation and change oil weights based on accurate operational observations. Not out of warranty yet, but may make that mod when our 2012 is over 100k.
  11. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I see no reason to change from Toyota's spec.
    Jim Swart likes this.
