what version of techstream can be used on a gen1 (2003) ?
Discussion in 'Generation 1 Prius Discussion' started by carlford, Oct 7, 2021.
  1. carlford
    carlford Junior Member
    Louisville`
    2003 Prius
    I
    I acquired an old gen 1 and need to scan it and look at the battery. I have a vxdiag and TIS Ver 15.00.026 that is working now but It will not get into the gen1 for me. was going to program a new key fob as the pedal dance just will not work for me. Thanks in advance, Carl Ford
  2. AlexY
    AlexY Member
    160
    45
    UK
    Techstream? Any. I use V12.20.024
    Are you sure VXDIAG is compatible with gen1?
  3. dolj
    dolj Senior Member
    7,634
    3,852
    Wellington, New Zealand
    @ChapmanF will be along soon and can answer that.
  4. ChapmanF
    15,509
    Here I am, and my answer is ... I don't know. I didn't have any Techstream rig when I had my Gen 1.
  5. Mukhtiar
    Mukhtiar Junior Member
    Espanola New Mexico
    2002 Prius
    I posted about my Gen 1 head gasket change. I'm asking if anyone has any experience with CARLY as a diagnostic tool..
    I have tried the pedal dance unsuccessfully. The solution I used was to relocate the transponder antenna from its home encircling the key hole to a secured float in inside the steering enclosure, then taping a programed key in the antenna. Voila! The car always sees the transponder and properly cut non programed key will now start the car.
    for video explanation
    #5 Mukhtiar, Oct 8, 2021
