What would cause inverter not to charge to HV battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by popptj2001, Jul 4, 2017.
  1. popptj2001
    popptj2001 Member
    79
    50
    To make a long story short...
    Replaced HV Battery due to P0A80
    Started car and after 10-12 seconds car dies with P3190 (loss of power). Discovered after measuring voltage at the HV battery terminals before car starts (204 V), and after car starts (197V) that the inverter wasn't charging <although I had no codes indicating bad inverter>.
    Went ahead and replaced the inverter and still have the same issue. Watching my battery indicator, the HV battery after about 10-12 seconds goes from 5 bars to 1 then shuts off with "problem"...red triangle with code P3190 (loss of power).
    I do have an extra ECM if this is the recommended route, although I have never had to replace.
    Thanks!
  2. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    With what did you replace the HV battery? If if was a rebuilt, it is likely faulty.
    Also the current battery, at 204 V, is below the 40% SOC threshold above which the HV battery ECU likes to keep the voltage. You need to give the HV battery a full charge before any further attempts to start the ICE.
    I don't believe there was anything wrong with the inverter or the DC/DC converter.
    You can then attempt to trace the reason the ICE looses power.
    #2 dolj, Jul 4, 2017
    m.wynn and JC91006 like this.
  3. popptj2001
    popptj2001 Member
    79
    50
    Battery came from a 2009 wrecked prius with 100,000 miles. The wrecked car was running the day he took it out and gave it to me. (trustworthy mechanic).
    The HV battery is possibly below threshold now because I started the car several times and even drove it.......for 10-15 seconds before it died every time.
    Measuring across the terminals at the HV battery, there should be a change in voltage up from 204 when the ICE starts yes? Am I measuring this correctly?
    It just looks like to me the HV battery isn't getting charged when the ICE is on.
  4. JC91006
    16,480
    8,397
    A hv battery would not come out of a running car at 204v. You would have to ask this trustworthy guy again.
    You need to determine if that hv battery is any good, it seems like it has failed modules, that's why it's measuring 204v
    Since you're able to take the cover off the hv battery, are all the serial numbers on the modules similar? What's the first 4 numbers/letters on the module serial?
    #4 JC91006, Jul 4, 2017
  5. popptj2001
    popptj2001 Member
    79
    50
    If I measure across the terminals should voltage go up when ice is running
  6. popptj2001
    popptj2001 Member
    79
    50
    jc....if the hv battery was problematic, it would indicate that through the appropriate PO code?
    Also.....I disassembled the hv battery before I installed and all cells measured anywhere from 7.3-7.5 volts
  7. JC91006
    16,480
    8,397
    Why did you disassemble the pack?
    7.3v - 7.5v would mean you have somewhat of an imbalance battery. The variance should not be that high (although it's acceptable in the parameters of the prius ecu).
    I would think if the car had p0a80 and you replaced the battery, the problem lies in the battery. Not the inverter
    You should check all your wiring, make sure you didn't break anything. Also check the torque of the terminal nuts, 48 inch pounds.
  8. JC91006
    16,480
    8,397
    You should check your 12v battery too, make sure it's fully charged. And when running, the 12v should measure around 14v.
    You went from changing the hv battery, to now an inverter. An extra diagnostic as the inverter can be bad now
    If a car dies while it's running, it's usually because the 12v is not being charged by the dc/dc converter.
  9. popptj2001
    popptj2001 Member
    79
    50
    I opened it and inspected it for preventative maintenance....cleaned some slight corrosion buildup off the terminals and copper jumpers. When I had the jumpers loose I measured voltage.
    When the ICE is running....should voltage across the hv terminals go up?
    And I have a brand new 12v battery. That was my first step in this process .
  10. JC91006
    16,480
    8,397
    I've never had to be bold enough to directly measure the hv battery while the engine is running. If I need live data, I would safely use my miniVCI and techstream. But there should be a voltage jump if it's charging.
    You should run some of the test I mentioned, as a new 12v does not mean is charged. You have to eliminate the simple things.
    How did you clean the corrosion? How tight did you tighten the terminal nuts? Do you still have your old battery?
    #10 JC91006, Jul 4, 2017
  11. popptj2001
    popptj2001 Member
    79
    50
    Thanks for the info so far...
    I cleaned the terminals with a small brass wire cup brush on a drill. Worked great.
    And yes...bold and probably stupid.... yes, but I measured the voltage across the terminals and voltage dropped to 197 when the ICE engaged.
  12. JC91006
    16,480
    8,397
    You'll need to charge the hv battery before you can test more. It's out of its operating range.
    If the car will start,
    set your parking brake,
    press and hold the brake with one foot,
    put the car in drive
    and press the gas pedal all the way to the floor.
    This will force charge the hv battery
    #12 JC91006, Jul 4, 2017
    m.wynn likes this.
  13. popptj2001
    popptj2001 Member
    79
    50
    Attempted force charge.....no luck. Ice shuts down with problem 3190.
  14. ChapmanF
    15,561
    When you hear the engine spinning for a dozen seconds, and then giving up with a P3190, that means the engine never produced enough power to keep running on its own. That's why there wasn't excess power to put into charging the battery; the battery was being used to spin the engine.
    -Chap
    popptj2001 likes this.
  15. popptj2001
    popptj2001 Member
    79
    50
    As described here is what's happening.
    I should note this prius is a 07 with 475000 miles. (original fuel pump). I have replaced just about everything under the hood including engine, trans, inverter etc etc etc. Car was running perfectly prior to getting the P0A80. 12v replaced, HV replaced, inverter replaced (I have a parts guy who gives me great deals). I want to hit 500,000 miles..it's personal!
    Getting P3190....engine issue. Maybe it's a fuel delivery issue? I just cleaned the throttle body with cleaner. I do have techstream software but have only hooked it up once and really not sure what to look for.
  16. popptj2001
    popptj2001 Member
    79
    50
    Here is my forced charge attempt. Shutters horribly then dies.
    #16 popptj2001, Jul 4, 2017
  17. JC91006
    16,480
    8,397
    Wow, this car has a lot of miles.
    Does the car have fuel? If you're not sure, you would need to add 5 gallons for the car to register it.
    If you've cranked the engine numerous times and it won't start, there maybe other issues. You would have to determine everything else you've touched is working properly.
  18. popptj2001
    popptj2001 Member
    79
    50
    Tks yes lots of miles. Has been a great car. I don't want to let it go yet..I added fuel up to half a tank. It does indeed start and runs great.....for short period of time....13 seconds in the above video.
  19. JC91006
    16,480
    8,397
    Well you'll need to get that battery charged up, maybe you can ask Matt for a little help. He's at texashybridbatteries.com
    He's always providing helpful ideas and troubleshooting tips.
  20. ChapmanF
    15,561
    A Prius can always sound like it starts and runs great for 13 seconds—because MG1 and the traction battery crank it at about 1200 rpm, not the much lower rpm conventional cars crank at. When after 13 seconds the cranking stops and P3190 registers, that does not mean the engine ever started or ran.
    -Chap
