What's a realistic fuel economy for a Gen 4?
Discussion in 'Gen 4 Prius Fuel Economy' started by George W, Apr 19, 2026.
  1. George W
    George W Senior Member
    933
    519
    San Antonio
    I just purchased a 2019 Prius 2 this past week. The first full tank is indicating 55 to 56 miles per gallon in mixed driving, with a total expected range of about 490 MI. Since I'm a Gen 4 newbie, I'm curious if this is typical for a car with 140K. Thank you.
  2. Mendel Leisk
    42,117
    Google: fuelly 2019 Prius.
    George W likes this.
  3. notspam3
    notspam3 Member
    122
    66
    Toronto
    2024 Prius Prime
    XSE Premium
    Forget google AI slop, here's real world fuel economy and you can search by sub-model, year and compare your location
    Fuelly.com
    https://www.fuelly.com/car/toyota/prius
    The people who have uploaded lots of data regularly tend to have more reliable stats.
    If you are flat ground in a warm climate you will tend to get better results than cold climate with hills and a lead foot.
    For 2019 you are looking on average 4.5-5.0 L/100km
  4. Mendel Leisk
    42,117
    Dividing 235.2 by either litres per 100 kms or mpg (US) converts it to the other. For example, converting 5 litres per 100 kms:
    235.2/5=47.04.
    kinda cool: at least on my iPhone with Safari, typing the above, as soon as I type the equal sign it auto-completes the outcome.
  5. BiomedO1
    BiomedO1 Senior Member
    4,407
    2,318
    Left Coast
    That's kind of a tricky question to answer, but I believe the EPA states 52 mpg combined.
    The variables that effect this is driver's input (lead-foot); terrain (hills, mountain), weather (cold, sunny), and general car's shape (under carriage air diverters, brakes dragging, junk in the trunk). All these little things add and subtract to this car's average mpg, vs an all gas car. Most of what I listed above wouldn't affect gasoline cars as much. Even with all the negatives; that car still gets better mpg than most other cars on the road today. I do know that you'll take a big hit in mpg if you normally travel above 70 mph. People in Montana and Idaho report mpgs below 48 mpg averaging 80+ mph. Some of that may also be terrain related.
    Hope this helps.....
    FWIW; you should be looking for any deviations from YOUR normal mpg. That's the indicator that something's wrong with the car. If you loan the car out to someone else; that's going to punch a hole in your "normal" mpg.
    #5 BiomedO1, Apr 20, 2026
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,320
    933
    Monument, Colorado USA
    Yep, that sounds nominal. We have a 2017 and 2019 and can range from 44 mpg (driving like an F1 driver on the interstate) to 65 mpg using the pulse-and-glide method.
    MPGs will go down during the hotter months when you run the A/C, which is normal....electric A/C compressor can suck quite a bit of sparks from the system which lowers MPGs.
    Has the car been maintained? If transmission hasn't been serviced, make sure you get that done....it's just a drain-and-fill so not an expensive job. (Same for engine and traction coolants, will need changing if they didn't do that.)
  7. bisco
    52,634
    that is very good mileage! did you calculate at the pump? the dash readout is optimistic
  8. ColoradoBoo
    1,320
    933
    I only trust the real data from gallons at the pump when refilling as the car isn't very accurate in her estimates!! (I use my "Trip A" for this when I'm tracking MPGs.)
  9. Mendel Leisk
    42,117
    I reset Trip A at each fillup, note the kilometers, but also note the odometer kilometers. The latter is my bullet-proof go-to, the former just for back-up, and "optimistic" mpg feedback during the tank. I use an Excel spreadsheet, the odometer values are entered, the trip values, calculated, subtracting previous odo from latest, and compared to what I noted at gas station, for a check.
    #9 Mendel Leisk, Apr 20, 2026
  10. notspam3
    notspam3 Member
    122
    66
    Toronto
    2024 Prius Prime
    XSE Premium
    You use Fuelly and a spreadsheet! Dedication!
    I've been using Fuelly for about 20 years now along with a paper log book for the accountant. You can set up Fuelly to display metric and imperial units.
  11. Mendel Leisk
    42,117
    Oops: just noticed a typo in my spreadsheet dates (line 222).
    ColoradoBoo likes this.
  12. George W
    933
    519
    San Antonio
    The Carfax indicated that routine oil changes were done, but no information on ecvt fluid, that is a goal of mine, I did that on my Gen 2. I just haven't researched the exact locations and bolt sizes on the Gen 4. Thank you.
  13. BiomedO1
    4,407
    2,318
    Left Coast
    look for 10mm hex. fill hex is near the passenger side output half-shaft. The drain, I don't recall faces either the passenger or drivers side. If you have a 10mm hex that faces straight down - that's NOT it. The drain bolt screws in from the side; I just don't remember which side - but it's identical to your fill bolt.
    Hope this helps......
  14. Mendel Leisk
    42,117
    Transaxle fluid change info attached. Also see link in my signature, it’s 3rd gen specific but some relevance (on a phone turn it landscape to see signatures).
  15. PHEVisthefuture
    PHEVisthefuture Junior Member
    76
    Illinois
    My Gen 4 mpg has been hovering in the 50's mpg range when cruising between 55-65MPH. At higher speeds, MPG tanks, but that is to be expected with any car. Just leaving earlier & taking 45-55MPH back roads gets me a bunch of extra MPG. Average 57 MPG with average speed at or slightly under 50MPH.
