What's behind the rear bumper?
Discussion in 'Gen 2 Prius Main Forum' started by zenMachine, Aug 25, 2008.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    We got rear-ended at a stop light last weekend. The driver behind us thought the light had turned green so he went forward and rammed into our Prius. Luckily, his car is a Camry and his speed was pretty slow so the damage was relatively minor. The bumper got squished just enough to pop the rivets out on the two sides, and the lower lip of the rear hatch got bent just a little bit to where now you have to slam down pretty hard to close the hatch. Otherwise everything looks OK.
    Took the car to the body shop, the Toyota guy said they needed to examine behind the bumper to see if anything was damaged there.
    My question to our panel of experts: what IS behind that rear bumper???
  2. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    Exactly what happened to mine.
    They replaced the bumper...a piece of hard styrofoam absorber behind it...and two bent metal shock absorbing pieces. Sounds like it worked as advertised.
    Total cost about $1200.
  3. Patrick Wong
    18,200
    6,479
    See attached .pdf file. Can the hatch be repaired or will it be replaced?
  4. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    I can tell you what's behind my back bumper: some jackass in a 4x4 pickup truck blaring country music and fixin' to reach for one of the rifles in his gun rack until his girlfriend stops his hand and says, "it ain't worth it Cletus, you've been savin' that last bullet for yer ex-wife."
  5. slair
    slair Ubër Senior Member
    404
    Lafayette, IN
    Right.
    Spot.
    On.
  6. Qlara
    Qlara New Member
    488
    That's suck to be rear-ended by a mindless driver.
    Looks like the rear has crumple slightly inward, thus the hatch got bent a little. Do they have to replace the rear hatch too or just 'fix' the bent?
  7. zenMachine
    3,355
    300
    The bent in the hatch is so slight that I didn't notice it at first. But the adjuster was experienced enough to immediately pop the hatch to look for it. Sure enough, the hatch wouldn't close properly when you let it drop down. I don't think it'll need to be replaced. The estimate is only like $1200.
    Strangely, he also put on the estimate sheet the cost for replacing the Toyota badge and emblem that I debadged long ago. I wonder if he thought they "fell off" from the hit, or if they needed to be replaced for advertising purposes. :)
  8. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    Just so you know, it's not behind the "bumper". It's behind the "bumper cover". You will find the actual bumper behind the bumper cover. As posted above it consists of a Styrofoam block and a few bits of crumplable steel.
    Sounds like they did their job absorbing the forces, and preventing the body from being bent.
  9. McShemp
    McShemp New Member
    371
    SA, TX
    Isn't there an SKS transmitter/sensor behind the bumper cover too? I seem to remember it needing to be replaced on my wife's Prius when it was rear ended.
  10. hill
    8,253
    naw ... the SKS receiver is located back a bit farther. It's under the trunk, in there about 2 feet back, a tad towards the left as you're looking in
  11. Patrick Wong
    18,200
    6,479
    Well, hill is referring to the "Luggage Electrical Key Oscillator (Inner)" while McShemp is referring to the "Luggage Electrical Key Oscillator (Outer)"; or maybe the "Electrical Key Antenna (Rear)". See the attached .pdf for details.
  12. orracle
    orracle Whaddaya mean "senior" member?
    441
    Gurnee, IL
    Considering where you and I live, Tony, another possibility is some Cheesehead looking for the Mall or Six Flags:D
  13. McShemp
    McShemp New Member
    371
    SA, TX
    It was the Electrical Key Antenna (Rear). Anyway, the accident caused about $1400 in damages without needing to tweak the rear hatch (whew!).
