Whats going on?? 2013 Prius C
Discussion in 'Prius c Technical Discussion' started by Javierz0509, Dec 14, 2017.
Thread Status:
Not open for further replies.
  1. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    i made it video to make it easy, this is for a 2013 prius c any help would be appreciate.
    49,492
    what you are reading is the 12v battery voltage while it is being charged, not the hybrid battery. i don't see a problem. the inverter converter charges the 12v as necessary.
    if you want to test the 12v, get a digital volt meter and check after the car has been off a few hours.
  3. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    i will do that @bisco and report back, thanks.
  4. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    Update.. I am at the toyota service dep to see what they say
  5. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    they say its the battery pack, and want $3,516 :(
  6. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Unless you started tinkering around with things you didn't know anything about - and threw a bunch of codes as a result. I would find another Toyota dealer to take a look at that Prius. I'm with bisco up there & didn't see the problem to begin with.
  7. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    whoops - didn't realize until just now that you have another thread on this active with what appears to be big problems. Might want to request this one be closed so someone like me doesn't reply without having all the info.
Thread Status:
