What's that stuff on my windshield?
Discussion in 'Gen 2 Prius Main Forum' started by Vic Doucette, Jun 10, 2007.
  1. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    I'm thinking of getting my windows tinted -- well, as much as you can in Michigan, anyway -- including a strip across the top of the windshield. But what's that stuff at the top of the windshield behind the mirror? And would it hurt anything if it were covered with a strip of tinting?
  2. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    612
    23
    Those dots are "supposed" to provide some shade, but it doesn't work very well. It serves no other purpose, so it's perfectly OK to cover them up.
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    They actually are designed purely for aesthetics, to make the rearview mirror look better from the outside. Not for shade. Cover em up.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Well, -I- think it's for glare reduction when you look in the mirror ;) . But to each his own interpretation of function. It's safe to put the tinting over it.
  5. SW03ES
    2,480
    176
    Gaithersburg, MD
    Ask a windshield installer what its for. Its not for glare reduction, its simply for appearances sake.
    Simply believing something is true does not make it so ;)
  6. vdubstress
    vdubstress Junior Member
    47
    Remember though the tint might not stick as well in the area with the dots. It is not a smooth surface so it might look kinda funky from the outside of the car.
  7. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I thought it is for glare reduction because the two shades (driver and passenger) doesn't cover that middle part when then sun is hitting the windshield. It has helped me before in this situation.
  8. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I thought it was there to reduce glare on the MFD.
  9. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    The true purpose for those dots is to catch lint from towels so it isn't left in your safety area of your field of vision after you clean the inside of the window.
  10. SW03ES
    2,480
    176
    Gaithersburg, MD
    Just to make you crazy LOL
  11. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    They are for glare reduction. Here is a link to an aftermarket version called Suntamer, so you can add more if you want!
    http://www.autosportcatalog.com/index.cfm?...2397&cid=61
    "You'll see overhead signs and changing traffic lights, but you won't be blinded by the glare of the sun sneaking between your visors."
  12. tochatihu
    tochatihu Senior Member
    9,059
    3,529
    Kunming Yunnan China
    2001 Prius
    Classic Prius lacked that glare reduction feature. I had to add my own :)
  13. skandale
    skandale Member
    101
    I've been told that most modern windshields contains a reflective layer to stop heat (and/or UV) to enter the car. The problem is that this layer also blocks signals (doohickeys for automatic toll booths and to some extent GPS signals).
    The "shaded" area around the mirror does not have this layer, and thus will not block these signals. And it's very parctical to put a GPS antenna or other stuff behind mirror, out of view.
    Stein Tore
    Currently owner of a 2005 Peugeot 1007. Have ordered a Prius with estimated delivery mid September...
  14. priusincc
    priusincc Member
    332
    16
    NV
    <div class='quotetop'>QUOTE(vdubstress @ Jun 10 2007, 06:43 PM) [snapback]459384[/snapback]</div>
    I had a strip put across top of windshield, surprisingly the tint film stuck and it looks OK.
    I agree with Michgal007, the dots behind mirror provide shade for the space between sun visors.
  15. mrsgdlite
    mrsgdlite New Member
    <div class='quotetop'>QUOTE(Vic Doucette @ Jun 10 2007, 03:48 PM) [snapback]459255[/snapback]</div>
    They cut around that on my tint job. The tint goes right up to the outer edge of the dots.
