What's the beep mean?
Discussion in 'Gen 3 Prius Technical Discussion' started by Whiteyprius, Oct 3, 2017.
  1. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    My Gen 3 (2012) hatchback now beeps when I open the door to get in. What's up? Thanks!
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    There is a beep you can configure when the door unlocks, so if you're coming up to a locked car and use SKS (hands free/fob in pocket) to unlock as you put your hand on the handle, then it would beep as you open the door...
    52,542
    could be a low 12v or fob battery...
  4. worrachai
    worrachai Junior Member
    48
    thailand
    I remember that fob battery low will show on dash when stop engine. But low 12v, I don't know. Are there signal
  5. Whiteyprius
    389
    105
    North Carolina, USA
    Thanks for your response, but this is different. It's a long continual beep -- a couple of seconds.
    FuelMiser likes this.
  6. Whiteyprius
    389
    105
    North Carolina, USA
    Yeah, could be. I'm hoping a low fob battery. I'll try that first. Thanks!
  7. thuwaragan
    thuwaragan Junior Member
    Boston, MA
    I believe one of your windows (or sunroof, if you have one) is open (even if it's just a crack). Might we worth opening and closing all of them
  8. worrachai
    48
    thailand
    Agree with your comment too.
