What's the deal with the fob?
Discussion in 'Gen 3 Prius Technical Discussion' started by nudriver, Nov 13, 2017.
  1. nudriver
    nudriver Member
    222
    26
    los angeles
    So I have been getting a warning signal that my key battery is low. I tried out my back up fob and that doesn't set the alarm so obviously that battery is dead as well. I know there is a real key hidden in the fob so I can lock the doors, but I had to hold up my fob with the dying battery to the power switch this morning to start the car, and I am nervous about driving tomorrow. My questions:
    1. How long will the power start with me holding the fob up to the switch? Once the battery dies completely will that no longer work as a method?
    2. How much does it cost to change the battery and what's the cheapest, easiest route?
    3. If the battery dies completely, will my car stop in the middle of the road?
    Thanks!
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Dealer will charge about $5.00 and show you how, or buy 3/4 on Ebay for about $3.00
    Don’t let this go, do it now, why be inconvenienced?
  3. nudriver
    nudriver Member
    222
    26
    los angeles
    Wow, that cheap? You sure? And what are the risks I run before I can get to the dealership?
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    1. As long your car starts this method will always work. Think of it as NFC. Does your credit card ever run out of battery?
    2. It's $2 but you can't buy just 1. I bought a 5 pack on Amazon.
    3. No. That's a safety hazard. You can toss the fob out the window and the car will drive fine.
    I drain the battery all the way before I change it out. I don't like wasting things. Using the mechanical key is not an inconvenience.
    jjmerp and fuzzy1 like this.
  5. Andyprius1
    2,327
    859
    Cool CA
    You can also disconnect the 12 V Battery after starting.
  6. bisco
    49,372
    1) forever
    2) cheap and easy are polar opposites
    3) no
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Forever, but it is a needless pain
    Under $6, Cheapest may be Amazon, but the easiest may be a local Walmart. Your fob battery may well be a CR1632, mine is.
    amazon.com/Duracell-CR1632-1632-Remote-Batteries/dp/B00JAPY7C8
    No. In fact you can drive forever without the fob at all so long as you never turn it off.
  8. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    Of course, while the vehicle will keep running we do not recommend doing this while driving (y)
    Andyprius1 likes this.
  9. RobH
    RobH Senior Member
    2,369
    979
    70
    Sunnyvale, California
    The most important reason to replace a dead fob battery is that dead batteries ooze crud that destroys electronics. So even if you don't replace a dead battery, remove it to protect the circuit board.
    #9 RobH, Nov 13, 2017
    jerrymildred likes this.
  10. nudriver
    nudriver Member
    222
    26
    los angeles
    I don't get how the fob will still work after the battery dies.
  11. ILuvMyPriusToo
    778
    514
    Outside Philly, PA
    The battery in the fob is for wireless communication for smart key functions - remote lock/unlock and starting the car with the key in the car but not in the slot. Those don't work if the battery in the fob is dead.
    However, the fob has an immobilizer chip in it that can be read directly by the car's electronics if it is in or very close to the slot in the dash. That doesn't require fob battery power, just like reading the chip in your credit card also does not require an internal battery in the card (as was pointed out above). To test this, just take the battery out of your fob and put the fob in the slot - car will start right up! (y)
    nudriver likes this.
  12. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    My dealer charged me $6 something and the parts guy changed the battery for me.
  13. nudriver
    nudriver Member
    222
    26
    los angeles
    What slot?
  14. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The slot is a Gen 2 feature, you have a Gen 3 and just hold the fob near the the Power button. Time marches on and Prius improve.
    ILuvMyPriusToo and nudriver like this.
  15. nudriver
    nudriver Member
    222
    26
    los angeles
    Thanks for all the help guys! Good to know I will be able to get to work tomorrow.
  16. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    CR1632 button cell batteries. If possible, buy a 2-pack so you can replace the batteries in both fobs at the same time.
    jerrymildred and PosauneGuy like this.
  17. nudriver
    nudriver Member
    222
    26
    los angeles
    Thanks for the help guys. Went to the dealership to make my life easier. Charged me $8.75 (including tax), which is a ripoff I know, but saved me the hassle of trying to figure out how to open fob, find battery deal and replace it. Though now that I've done this twice, and I paid attention to how they opened the fob, I'll do it myself next time. To compensate for the overcharge, I got a free latte inside the dealership. If that was worth about three bucks, I'd say I got my money's worth.;)
  18. Mendel Leisk
    38,646
    That's a very fair price. Batteries don't grow on trees. They took the time to replace your batteries, virtually for cost, and you're still not happy?
  19. nudriver
    nudriver Member
    222
    26
    los angeles
    That's not what I said!
  20. Mendel Leisk
    38,646
    You said $8.75 to procure and install fob battery was a rip off? Up here 2-pack is at least $5. These guys have overhead, salaries, business taxes, equipment. And a latte machine, lol.
    jerrymildred and mygel like this.
