What's the difference between EV vs early HV mode?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by plugged-in, Mar 13, 2012.
  1. plugged-in
    plugged-in Junior Member
    22
    irvine
    Is there a difference between full EV mode and the early HV mode where you are in EV(left half of the indicator on the HSI screen)? Aren't you in full electric in both situations? If so, then why would you need to manually toggle between the two modes?
  2. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    HV mode will only let you use a small range of the battery making it behave like the regular hybrid Prius. This means at some point, it won't let you drain the battery anymore to travel further on purely EV miles even if you have plenty of energy in the battery. EV mode lets you use the full usable range of the battery. Also, EV mode lets you drive at higher speeds on electricity only.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    In HV mode, the gas engine will kick in for power request more than ~15hp. PHV EV mode raises that to ~50hp. The EV speed limit was also raised from 25mph to 62mph.
    We are still working on the gauges in Torque app so, the horsepower values could be confirmed.
  4. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Also, when the engine fires up while in EV mode, excess electricity will increase the range. 3 times that happened to me this morning when the defroster kicked in. Each time, the EV range increased about 1/2 mile.
    It's a fascinating benefit of the power-split system often overlooked.
