What's the difference between these parts?
Discussion in 'Prime Main Forum (2017-2022)' started by John Bishop, Apr 18, 2025.
  1. John Bishop
    John Bishop New Member
    Des Moines
    2022 Prius Prime
    I need to replace my 2022 Prius Prime Limited front grille. There are two grille options that fit my car:
    53101-47150
    53101-47160
    One is 200 more expensive. What's the difference?
    PS: I can't post links.
    51,019
    do they all have auto shutters?
  3. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    You should probably do a parts search using your VIN to ensure you get the correct part.
    Both parts you've indicated, stated 'no paint req.' I know the exterior front end is painted plastic, so the pictures probably isn't inductive of the actual part. Possibly a sub-assembly that snaps onto or behind the painted surfaces. There's also that smoked translucent assembly that covers a good portion of the part pictured.
    Hope this helps.......
