What's The Difference Between Traction Control and VSC?
Discussion in 'Gen 2 Prius Main Forum' started by boulder_bum, May 3, 2007.
  1. boulder_bum
    boulder_bum Senior Member
    1,371
    38
    Castle Rock, CO
    By the little research I've done, it sounds like traction control and vehicle stability control (VSC) do the same thing. Nevertheless, the former comes standard with all Prii while the latter is an upgrade.
    How do traction control and VSC differ?
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Here is one of the many results from a Google search.
    What is the difference between ESC, ABS and traction control?
    Where ABS and traction control were effective in assisting with braking and acceleration, the addition of the extra sensors enables ESC to offer the driver assistance in turning under hazardous conditions.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    I'm sure others will provide much greater detail, but in short:
    Traction Control keeps the front wheels from spinning when power is applied and there isn't traction. The reason it is standard is that spinning the tires too fast can over rev the HSD and damage it.
    VSC (Vehicle Stability Control) keeps the car going in the direction you are steering. It measure the steering angle and yaw of the car as you go around a curve. If the direction you are steering and the direction the car is moving don't match, it can brake wheels individually to get the car to line up with the direction you want to go. It's an extra since it involves a yaw sensor and computer to integrate the feeds and outputs to the brakes.
    When I tried to post this at 17:23 PDT, PriusChat seemed to be down or in a weird state.
  4. chogan
    chogan New Member
    590
    Vienna, VA
    <div class='quotetop'>QUOTE(Bill Merchant @ May 3 2007, 08:26 PM) [snapback]435128[/snapback]</div>
    Exactly right. Sombody else here mentioned that the power steering is linked into it as well. My two cents: I got VSC entirely by accident. Didn't know what it was when I bought the car. But I have come to learn that it appears to be really effective in helping to avoid bad accidents -- like you end up with 25% to 33% fewer reportable accidents, based on trials in a variety of cars. That's why the insurance industry and Consumer Reports, among others, are pushing it really hard. So I hope I never need it but I'm glad I got it. You ought to do a search here -- somebody posted a thread with link to a video of a VSC-equippped care doing emergency avoidance.
  5. Tideland Prius
    16,445
    no.. only VDIM controls the power steering (e.g. GS sedans so equipped).
    VSC is just a yaw sensor.
    We should get a definite answer (I don't have time to write a complete answer right now) and then sticky this thread.
  6. daniel
    14,487
    1,519
    Spokane, WA
    Bill Merchant beat me to the simple explanation.
    I will add that when I lived in Fargo, ND, it was common to find ice forming right at the spot where cars stop at an intersection, so that cars would spin their tires as they tried to move away from the stop. You'd see them sort of sidling back and forth, like a cat preparing to pounce, as they tried to move away from their spot on the ice.
    Traction Control was so effective, that I was able to get through these kinds of intersections faster than most other cars.
    VSC is what saves your hide when you start to skid in a turn, and it saved mine several times.
    ABS (though the OP didn't ask) keeps you going in a straight line when you brake hard on ice, or other slippery conditions.
    The first two operate by applying brakes selectively to a single wheel when the computer determines it's necessary. ABS operates by releasing the brakes on one or more wheels, as deemed necessary by the computer.
